clifford alarm lost its arm/disarm chirp
Results 1 to 17 of 17
Thread: clifford alarm lost its arm/disarm chirp
    Wolverhampton
    corsa gsi
    I have a clifford concept 300 and it used to chirp once when it was disarmed, and twice when it was armed, but it has suddenly stopped doing this, any idea why?
    16.1s 1/4 mile with a c16xe - mantzel style inlet, 4-1 exhuast, de-cat straight through and chipped, not that bad a time.14.7s 1/4 mile honda civic 1992 sir 1.6 - decat and induction kit, now thats a good time. Time to go jap i think!
    Mar 2007
    hertfordshire
    c20xe & let cav's
    is it on VALET mode? (red light stays on all the time)
    Aug 2004
    West Sussex
    Cavalier Turbo
    I take it the siren still goes off when the alarm is triggered? if so the battery in the siren is probably screwed, and you will need to purchase a new siren
    Jan 2006
    cambs
    07 astra cdti sri 150 xp
    look for a block of fuses or should i say 2 fuses in a block in the steering colum.probly them fix one like that before
    Quote Originally Posted by sabo
    your so TIGHT, you squeek when you walk
    Rob
    Rob is offline
    MIGWeb User Rob's Avatar
    Tain
    Vectra CDTi
    Quote Originally Posted by show n shine View Post
    Valet mode only lasts until the car is started again.
    Quote Originally Posted by NOVA? View Post
    You can buy replacement batteries but they are a chew to fit. I did them on the wife's corsa and the chirps sometimes chirp and the siren never works!! lmao
    Melv - "you shouldn't be allowed boobs that size as your only a wee lassie"
    Dec 2001
    East Sussex
    Cav with TB's & lots
    It is a user feature to turn off or on the chirps. Read your user manual or download it (do a search on mig as there is a link) and turn it on again.
    IIRC if the siren battery is screwed it will still chirp as it uses the car battery (unless disconected).
    And those above are right about valet mode.
    Does seem to all point at you turning the chirps off.
    Wolverhampton
    corsa gsi
    I have tried the settings, and it still doesnt chirp. I never adjusted the settings at all, and one day it suddenely stopped, and i looked how to turn the chirp on, tried it and that didnt work either. Yes the siren does still sound when the alarm is triggered, so does the chirp not work off the car's batterey then, and where abouts are these fuses in the steering column, and what are they connected to. Thanks
    Wolverhampton
    corsa gsi
    The only other thing i have noticed, is that when i first bought the car everytime i went to start the engine i had to press the star button on the remote followed by the lock/unlock door button, to disable the immobiliser, this was done while the ignition was on. Now however when i unlock the car i can start it straigh away without having to disable the immobiliser, but that is only if i start the car as soon as i open the doors, if i wait 20 seconds then it reactivates the immobiliser. but again i havent adjusted anything on the car for this to happen
    Aug 2004
    Sheffield, S. Yorks
    GT
    If you haven't changed any settings and it used to chirp on arm/disarm then as already mentioned it is the siren backup battery that needs to be replaced. Maplin sell them for about £15 IIRC.
    Wolverhampton
    corsa gsi
    and i am guessing this is located in the siren itself, but it is tricky to change
    May 2003
    Sunny Old, Suffolk
    2.0 16v gsi 2wd
    my clifford has done the same thing u can hear the relay clicking but no sound spoke to a clifford fitter and he said the sierns go faulty and can be replaced for free
    life guarantee
    Worlds Fastest Cars
    myweb.tiscali.co.uk/sowhatsitcalled/worlds_fastest_cars.htm
    May 2003
    Sunny Old, Suffolk
    2.0 16v gsi 2wd
    For United Kingdom residents only:
    Following are instructions for exchanging your defective Clifford product for a replacement unit. We recommend that you first attempt to exchange defective product at the dealer where you purchased it; this is usually the fastest way to get a replacement. For Directed products that were installed in your vehicle by a Directed authorised retailer, you MUST contact the installing retailer for a replacement, and it must be re-installed by professionals per the stated warranty terms.
    For specific terms of coverage and other warranty terms, please refer to your Owner’s Guide. Copies of the Guides can also be found online in our Product Guides section.
    Your product warranty starts on the date that you purchased the product, so a copy of your store receipt with the purchase date must be provided upon return of any defective product.
    Per the stated warranty terms that you received with your product, Directed may repair your defective product, or exchange it with a new or factory refurbished equivalent at Directed's option.
    Your product warranty is voided if the product is damaged through negligence, misuse, or mishandling, or if any bar-coded labels are removed from the product.
    Directed will return your original defect to you at your expense if it is not covered by the terms of the warranty.
    Worlds Fastest Cars
    Wolverhampton
    corsa gsi
    cool cheers, i will locate a local dealer, as the prevoius owner had the alarm fitted, so not sure where it was done, not local to me anyway
    Jun 2005
    Midlands
    None
    Your battery back up has gone in your siren. We have dealed with many people with this same problem We are based in Birmingham.
    www.motorguarduk.co.uk
    Wolverhampton
    corsa gsi
    how much is it to change then
    Nov 2005
    Kent
    The lifetime guarantee is only valid if you're the person that had the alarm installed.
    I have the Concept 600...went through a stage of not working properly, then it started chirping, now it doesn't.
    Mar 2007
    hertfordshire
    c20xe & let cav's
    Lightbulb
    Most of these problems sound like POOR installations to me
