Originally Posted by jaye944 think its either 5 years OR the lifetime of the car (that you have it)
change the switch, or at least take it out and see if the connection is ok, or needs resolderings or cable connection is loose.
just a standard Toggle switch, Tandy/Maplins etc will stock it |
Standard toggle switch won't work for the G4/G5 alarms (which this must be, as anything pre-G4 didn't have blackjax)..
The G4/G5 valet switches offer a resistance when one button is pressed, and closed circuit for the other IIRC.
Check with your local dealer - last time I checked, a new valet switch was only about £7
