quickl help please
Results 1 to 7 of 7
Thread: quickl help please
    MIGWeb User GTE_lee's Avatar
    Oct 2005
    oswestry, shopshire
    Nova GTE
    quickl help please
    hi,
    i have a sigma cat 1 alarm (very sensative lol)
    well i need to know what is running the battery dwn, every 3-5 days i got to my car it is flat,(car isnt being driven),
    well i need to find out what is drawing the power, i have been told to...
    get multimeter and see if any power is being drawn from bettery when not started, then slowly remove fuses until i see a sudden drop in the drawn energy,
    well thing is with this alarm i think each time i remove a fuse it will go off because it has senced that the voltage has adjusted, is this correct??
    if so, how else could i do it??
    thanks lee
    Aug 2005
    'ULL
    Astra GSI III
    unplug every fuse apart from the alarm one
    Oct 2005
    oswestry, shopshire
    Nova GTE
    ye but i have been told that cat 1 alarms sence drop in voltage, and that can trigger it,
    lee
    Aug 2005
    'ULL
    Astra GSI III
    if it senses a drop in voltage and triggers it off then your alarm would be going off all the time if your loosin power in your battery. there is always something draining power, maybe it would siren if the voltage to the alarm unit is tampered with but nothing elese will
    MIGWeb User andrew_lumb's Avatar
    Apr 2004
    Huddersfield
    Skoda Octavia vRS
    surely if you remove all fuses other than the alarm fuse, and then reset the alarm, there will be no further 'drops'???
    Oct 2005
    oswestry, shopshire
    Nova GTE
    reset alarm???
    i dnt wanna remove all fuses n leave them out, i want to sort out wat if anything is draining battery!
    lee
    Mar 2004
    sunderland
    94 cav turbo
    have you already done a amp drain test
