kenwood head unit
Results 1 to 3 of 3
Thread: kenwood head unit
    May 2005
    kenwood head unit problems
    hi i have a kenwood 9021 cd head unit
    i started my car today and the head unit turned on and the radio played but no display then it went off and in to the mask mode
    has anyone had this problem or any tips on what to do cheers
    Jan 2005
    Sheffield
    Veccy GSI
    I've seen some problems like this before with kenwoods.
    Obviously if it has gone to mask and won't turn, you need to press the corner (bottom or top left - I think) to open it back up.
    The problems sounds like it could be one of 3 things.
    1. Your head unit is faulty
    2. Wiring problem
    3. The connection between the front and back has a problem.
    I have seen no. 3 a few times with kenwoods. So worth a look!
    Dave
    If my post contains the line 'Last edited by Nemesis;' Then don't trust anything above, as I didn't write it.
    May 2005
    lead
    hi
    took it out the car today and went up to my local repairer and they said its normaly the thin cable that has worn.
    i should have it back soon
