Safe mode
Just got a Corsa run-around and it needed the code in the stereo got the code but my m8 has been playing with it just need to no how to get it out of safe mode so I can put the code in.
Switch the stereo off, switch the ignition on, hold down the AS button on the stereo and switch on the stereo while still holding down the AS button. A beep should be heard and you can entre the code
If it still stays safe the ignition and radio need to be left on as a wrong code must have been entered
