electrical nighmare in my astra...help please!!!
Results 1 to 9 of 9
Thread: electrical nighmare in my astra...help please!!!
    Oct 2005
    Benn's garage
    hitler's taxi
    hi all. im having a bit of an electrical problem in my astra at the moment. while i drive during the day the date/ digi clock display in the centre console are lit up oragne...but when i use the headlights or flash the headlights it turns off could this be a problem with the earthing or a relay?
    also the lights behind the speedo are very very dim and i cant see how fast im going at night because it hardly lights up (ive even got pulled over on sunday night for speeding coz i thought i was doing 30 but i was doing over 40 )
    how easy would it be to change these LEDs behind the speedo, clock diplay and the temp setting under the clock display? i know evil on here sells LEDs and i might consider buying them
    cheers
    Sep 2004
    Kidderminster
    Vectra v6
    Try turning the dimmer up.
    Jan 2005
    Newport
    Focus LX
    Quote Originally Posted by harty
    Caught me out before , couldn't figure out what was wrong then it hit me.
    Jul 2002
    Leamington Spa
    Nissan Fairlady Z / JTin
    Aye, it's the dimmer!
    The instrument display dims when you turn the lights on as well, even more with them dimmed.
    It's the little horizontal dial under the headlight switch.
    Oct 2005
    Benn's garage
    hitler's taxi
    Quote Originally Posted by StationMiek
    that is most excelent guy before me has kept this car in such bad condition...problems keep crawling out everywhere
    Oct 2005
    Benn's garage
    hitler's taxi
    but what do i do about the clock turning itself of when the headlights are on?...is this due to bad earthing??
    also i need to change the LEDs in the temp control under the clock coz only haf of it turns on co how hard is it do remove a dash?
    thanks loads guys
    Jul 2002
    Leamington Spa
    Does it turn off completely when the headlights come on? Then I'd say dodgy wiring, there's a wire not doing what it should be somewhere.
    Sep 2004
    Kidderminster
    Vectra v6
    As soon as you turn the dimmer up the lights on the clock will come back.
    If its a mk3 astra you need to remove the plastic around the steering column, and then the plastic around the clocks. Then undo the clock screws.
    Go to the Gearbox, unscrew the speedo cable, and shuv it back thru the bulkhead a bit. Then you can get your hand around the back of the clocks, unplug the 2 loom multiplugs and the speedo cable. Then withdraw the clocks.
    The Little lights are the green plastic 1;s, and are available from vaux.
    Oct 2005
    Benn's garage
    hitler's taxi
    yes it turns off completly when the headlights are turned off
    thanks for that matey
