do i need a car to test my headunit lol
Results 1 to 25 of 25
Thread: do i need a car to test my headunit lol
    Apr 2005
    rotherham
    none at the moument
    Arrow do i need a car to test my headunit lol
    hya lads is there any chance of testing a headunit out stright to the battery. i would try it in my mine but my car is all riped apart getting a new engine in. and cant try it in m8s cars they have no block to put in car.
    MIGWeb User Scott G's Avatar
    May 2001
    57.37810N 2.08020W
    Honda Civic Typ
    You can see it powers up yes.
    My ex Mk3 Astra - My Corsa Sport - Join MIG Club ONLINE Here!
    "A wise man know everything, a clever man knows everyone"
    Apr 2005
    rotherham
    none at the moument
    how do i do it just put 2 wires from battey and then to the pins on the back of the head unit
    Apr 2005
    rotherham
    none at the moument
    any1
    Dec 2000
    uk
    If you’re going to try that make sure you have an inline fuse.
    Cant you just try it in one of your mates cars?
    Apr 2005
    rotherham
    none at the moument
    no because i cut my wires to fit it to mine. and my m8s cars all have the blocks
    Apr 2005
    rotherham
    none at the moument
    bump
    Nov 2004
    Gloucestershire, UK
    Astra GTE 2.0L 8V
    As said use inline fuse then just tack the power and ground wires onto the battery. Make sure no other wires touch out of the dangly mess!
    And did you know you could fix your loom easy enough by chopping what's missing off a scrap yard car? Would be a good idea to save you wrecking head unit looms in the future
    Apr 2002
    Essex - Colchester
    BMW
    dont go holding wires on the the pins on the back of the headunit, if you slip and accidenatly go to the wrong one, it will be dead in a puff of smoke... best bet is to go to a scrappy and cut one out.
    Apr 2005
    rotherham
    none at the moument
    Lightbulb
    i didnt no i could get a block from the scappy. could i just cut the block of one at a scrapy then solder the block to my wires what have been cut on the car
    Dec 2000
    uk
    You wont need to solder anything if you get a block from the same model as yours. Just match the wires up on the block to the ones coming from your car and then plug and play.
    Oct 2000
    Sunny Milton Keynes
    Bmw 3 series
    Don't use a car battery.
    Get a 1amp 12v power supply and use that.
    Even if you get it wrong using this, it won't kill the headunit, unlike the car battery.
    Yes.
    Nov 2004
    Gloucestershire, UK
    Astra GTE 2.0L 8V
    Yes solder it on is the best way, or if access limited (probably will be) then just use bullets.
    Feb 2003
    Berkshire
    Focus 1.8 TDCi
    Go to a Halfords store and ask to use there test board.
    Apr 2005
    rotherham
    none at the moument
    thanks for all the help lads
    Apr 2005
    rotherham
    none at the moument
    think its ****ed just put the red wire to + and the yellow to - and nothing happend
    Apr 2005
    rotherham
    none at the moument
    up what do you think lads lol
    Gagged
    Nov 2005
    Lincoln
    Is red + and yellow -?
    I never thought it was. . . But that mite just be me!
    Apr 2005
    rotherham
    none at the moument
    up and up
    Nov 2004
    Gloucestershire, UK
    Astra GTE 2.0L 8V
    red is permenant 12v, yellow is ign 12v switched
    black is ground
    Gagged
    Nov 2005
    Lincoln
    Quote Originally Posted by richie00boy
    black is ground
    This is what i always believed!!
    So you need the red to + and the black to - mate!
    Apr 2005
    rotherham
    none at the moument
    thanks lol glad theres ppl on here who know what they are talking about
    Apr 2002
    Essex - Colchester
    BMW
    you need to put yellow and red to + and black to - (thats assuming its aftermarket)
    if its standard vaux wiring, you need to put red and black to + and brown to -
    May 2005
    juust pop to hallfords the will do it for ya
  26. #25
    Apr 2005
    London
    Calibra 3.0 V6
    As said before just pop down to halfords and ask them to test ur radio on there board as if it dont work say u may want to buy a new one.
    No need to fart around with making up cables and going to scrappys just to test a radio.
