what fuse
Results 1 to 7 of 7
Thread: what fuse
    Apr 2005
    rotherham
    none at the moument
    Lightbulb what fuse
    hi my 10amp fuse has gone on my head unit will it damage it if i put a 25amp in
    Nov 2004
    Gloucestershire, UK
    Astra GTE 2.0L 8V
    Quite possibly, especially as you probably haven't remedied what caused the fuse to go in the first place. It's also a fire hazard.
    Jan 2005
    Sheffield
    Veccy GSI
    Quote Originally Posted by scott61985
    Try another 10 and check the wiring, if it still pops it, put a 15 in. 25 is bit much really.
    Are you using amps or the head unit to drive the speakers?
    If my post contains the line 'Last edited by Nemesis;' Then don't trust anything above, as I didn't write it.
    Apr 2005
    rotherham
    none at the moument
    its a m8s its strange had the battary off we put a new one in connected it back up and the head unit fuse went nd sum fuses in the fusebox
    Jan 2005
    Sheffield
    Veccy GSI
    Then definately stick another 10 in.
    Nov 2004
    Gloucestershire, UK
    Astra GTE 2.0L 8V
    The fuses are given a certain rating for a reason -- for protection. They are already specified with some 'spare' to allow for peaks etc. If you substitute a higher one you run the risk of operating the unit above it's temperature and/or current range. This will damage the unit and in a worst case could lead to fire.
    Dec 2002
    Hull
    Calibra 4x4 Turbo
    If the 10 amp fuse keeps blowing, you've got a fault. Putting a bigger fuse in won't solve the problem, you need to find the fault. Try taking the head unit out. If the fuse still blows, it's a problem with the wiring, if it doesn't, it's the head unit.
