NCDR1100/1500 Wiring Help.
Results 1 to 7 of 7
Thread: NCDR1100/1500 Wiring Help.
    Jun 2000
    Leicester
    Astra SRi 1.9 CDTI XP 3DR
    Question NCDR1100/1500 Wiring Help.
    Hi Guys. I'm trying to work out what each pin is on my Siemens NCDR1100 Satnav Unit (as fitted to the Coupe Turbo as an option). I have labeled the diagram up with numbers and filled out the ones I know. Also, there are a few I have guessed. Thanks for any help.
    1 Video Blue +
    2 Video Green +
    3 Video Red +
    4 Video RGB Common Ground
    5
    6 Sync (For Screen)
    7 CANBus High (Sat Nav)
    8
    9 Shield For Sync
    10 CANBus Low (Sat Nav)
    11 Diagnostics
    12 NC - No Connection
    13 Telephone Mute
    14 NC - no connection
    15 CD Changer Left + Input
    16 Telephone Audio Input +
    17 Reverse Switch (For GPS)
    18 CD Changer Common Ground Input
    19 Telephone Audio Input -
    20 CD Changer Right + Input
    21 Speaker Out Right Rear +
    22 Speaker Out Right Rear -
    23 Speaker Out Right Front +
    24 Speaker Out Right Front -
    25 Speaker Out Left Front +
    26 Speaker Out Left Front -
    27 Speaker Out Left Rear +
    28 Speaker Out Left Rear -
    29 Speed Sensor
    30 Steering Wheel Controls (Shown as 39 - D'oh!)
    31
    32 12v Constant Supply
    33 Aerial Power Control
    34 Illumination
    35 Ign Switch Supply?
    36 Ground
    Jun 2000
    Hampshire, UK
    Vectra SRi
    have added a couple mike
    CAN Bus is to do with the sat nav and is usually speed sensor connections
    some connections will be for the steering wheel controls
    Dom
    Dom is online now
    MIGClub Member Dom's Avatar
    Sep 2001
    Northants
    73bhp MK4 Astra POS
    NC normally means "No Connection" or "Not connected" if that helps solve a couple.
    I'd have thought the Shld would be a shield for one of the sensors (possibly the Sat Nav antenna if its got one)
    Dom
    Dom is online now
    Sep 2001
    Northants
    73bhp MK4 Astra POS
    And at a guess - pin 17 could be your reversing lights switch ?
    Apr 2002
    Essex - Colchester
    BMW
    11= diag
    6= sync - thatll go to the screen too i guess
    9= shield = for the sync wire?
    39?30=steering wheel controls
    29 = speed sensor
    34= illumination
    Jun 2000
    Leicester
    Only the following left:
    5. (Ter)
    8. (DBC)
    31. (AR)
    Sep 2004
    Kidderminster
    Vectra v6
    DBC is part of the magnetic movement sensor
