As per title?
At the moment it's running the two voicecoils in series, bridged across the amp's two channels
Should I run each voicecoil of a separate channel?
As per title?
Originally Posted by wayne451
what is the spec of the amp? and the ohm's per v/c on the sub?
It's for a friend...
It's an old-school Kenwood 2 channel 600W max amp, the sub is a 12" DB-audio. (not sure if it's raptor or t-rex - the cheaper of the two!)
I think the sub is 2ohms, not sure on the amp spec![]()
need to be sure on this the wrong info may lead to either the sub or amp's demise.![]()
Okay I'll drop him a text. Thanks for tryingOriginally Posted by mystery machine
