if i connect afther sales headunit i know i will loose steering wheel controls but what about lcd display will time and date temp still show on screen
ive fitted a alpine head unit in my mark 3 and it works fine m8 hope this helps
yes time and temp will show, date will show only if its turned off unless you cut one of the wires, (not sure which)
why not get a head unit that does the controls and display?
Astra Coupe Turbo '04
Can You Recommend Headunit Cheap Not Alot Of Money 2 Spend![]()
Depending on what head unit it is, you should be able to use the steering wheel controls with it. You will just need to buy an adaptor for the car/stereo.Originally Posted by nobby123
new pioneers/sony's etc are virtually all compatible![]()
Signum Elite 3.2v6 now replacing the old Omega MV6 Estate 3.0v6
for non-compatble stereo's, adaptor is around 30 quid from local halfords. If you also want to retain your LCD display, the adaptor for that is 60 quid.
roshan_j81@hotmail.com - Life moves pretty fast. If you don't stop and look around once in a while; you could miss it............
