as top cheers guys.
as top cheers guys.
you have a pm
JSRacing ...10.7 astra mk2 ...10.4 tigra and they are both 8v turbos both on megasquirt :)
Drag cars don't have to be pretty they just have to go fast in a straight line
bumping for this to, ive lost my PDF![]()
PM screamer he sent me the PDF whihc i have now deleted sorry.
got the pdf, i now need the diagram for the standard alarm so i can wire it in properly
You could try getting the vauxhall dealership software off ebay, seen it forsale on there, should contain all wiring diagrams.
that takes too long and costs money, lol
somone on here must know![]()
If anyone's got the wiring diagram for the ai606, or even pointers as how to write it up (I can't figure out which way the wires from the siren go into the main box), can they PM me please.
Ta,
Arth
The siren just plugs into the main unit. no need to cut and join wires.
this may help - been looking for myself and just found this pdf
http://homepage.ntlworld.com/betyoua...06_Install.pdf
ive got a list of the vauxhall colours somewhere and the correseponding ai606 colours. i will try and find it later an post up. cheers
some of the colours for the standard alarm dude. These are from a corsa b but were the same in my calibra and im sure they are the same throughout vaux range.
behind the glovebox
chassis = ground
thick red = perm 12v
black/purple = ignition while crank
black/green = indicator
black/white = indicator
light blue with red trace = cut for fuel immobilisor
grey = door trigger
Brown/red is Lock
Brown/White is unlock
Brown/Black is window closure
Blue/Black is deadlocking
Hope this helps
