Monitor In Ashtray Installation Pics. Mk3 Astra 56K Warning
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 28
Thread: Monitor In Ashtray Installation Pics. Mk3 Astra 56K Warning
    Aug 2004
    This is a project I’ve been slowly working on over the last few weeks and as it’s almost complete, I thought I’d post a few pictures using Imageshack..
    In brief, I wanted to have a monitor in my car for use with my DVD, TV and eventually Sat Nav, but I always felt my options where limited in my Mk3 Astra.
    The cost of those motorised all-in-one units are still a bit out of my budget, and I didn’t like the idea of dash mounting, as it would be on full view all the time. This got me thinking, would it be possible to fit a monitor inside my ashtray? If it could be done, this would be perfect as it’s out of site when not in use, and just one button press away for when I want to use it. The ashtray in this car gave a nice opening motion as if it was on a motor, so I set to work measuring up and checking out what’s possible. It turned out that the screen would have to unfold once the ashtray was open, I had an idea to use a motor to do this, something like a servo, but at this stage I wasn’t too worried about it.
    I did some research on the net to get some screen measurements, and eventually narrowed it down to this one:
    http://thebassbin.co.uk/shop/product...ts_id/878.html
    This one would fit perfectly and looked good quality. I was initially tempted to buy this one new, but as luck would have it, I got 2 off ebay for £100!
    So first thing to do was to take out the gear stick and handbrake surround. Once this was out I could work on cutting away all the bits of the ashtray that would get in the way. This turned out to be pretty much everything bar the hinged flap. As I mentioned earlier, the ashtray opened with a nice action (like a slow release on a stiff cog) and I wanted to keep this motion. The problem was that I needed the flap to open wider than it used to, so this meant cutting off the point where it locked to. This resulted in the flap opening slowly at first, but then when the cog ran out of teeth to grip to, it would just drop down quickly and this looked terrible. So to get round this I went to the scrap yard and bought another gear stick surround & ashtray, then set to work on extending the cog runner teeth:
    I basically just bolted a new section to the original at the correct distance the flap would need to open, so now I get that nice smooth motion all the way.
    The next step was to come up with some way for the monitor to hinge one the ashtray flap was open. This couldn’t have worked out better when I spotted a nail clipping kit from Next.. So I bought it and took all the foam shaped stuff out and flattened it with a hammer and a vice:
    I then marked out all the measurements and bought some tin snips to cut it out with.
    I used 3 bolts to secure it in:
    I then attached the monitor using screws into the original mounting plate holes on the back of the monitor.
    So now the screen was hinged and I was ready to set to work to find a solution for it to fold out using a motor. This proved to be impossible due to the lack of space when the screen was folded down and the ashtray flap closed, so I came up with a mechanical way to do it. Using left over metal strips form the Next nail care box I made a sort of pivoting hinge action. Using spring washers and bolts I tightened them up but not too tight so I could pull up the monitor and push it down again.
    This worked fine when out of the car, but when I did a test fit it turned out to be a bit clumsy, and would have meant touching the screen to fold it back down (I hate finger marks on a screen!)
    So I decided to add a sort of grip handle which extended from around the back. Again using left over strips of metal.
    This worked okay, but I was not 100% happy with it. It got me thinking how much better it would be if the screen didn’t need to fold down at all, then at the touch of the ashtray release button the screen would magically appear..
    It would be great if I could do this so I set about removing the centre console and see how much room was behind there. It was going to be tight but I was determined to do it!
    The main problem was a the big thick wiring loom, which as you can see would foul the monitor when it was folded away:
    This turned out to be pretty easy to move out the way, I just used cable ties. Lots of cable ties!
    So now with that out the way, I could clearly see what needed to be cut away from the dash:
    The metal bar going across was riveted on so I drilled out the rivets and temporarily removed it. This allowed me clear access to cut out the bottom section:
    I then refitted the metal bar using bolts as this was needed for the centre console facia to screw on to.
    After test fitting, the monitor would now fold away perfectly with no obstacles in its way.
    I used some rubber sheeting as a protection for the screen when it was folded away. There was nothing too near, but its better to be safe than sorry:
    I attached it using cable ties.
    I could now do away with whole pivoting scenario now and didn’t need to worry about motors or actuators anymore, thank god.
    I used a strip of some nice metal out of the back support on a hiking backpack:
    Then sprayed it all black:
    Ready to go in:
    I then ran all the cables, and hid the input box behind the glove compartment.
    And that’s it! Job done:
    I also took the opportunity to wire in some footwell lights into the driver and passenger side:
    These are great at night when you drop something by your feet..
    Let me know what you guys think, and if you would have done anything different.
    Jan 2005
    Newport
    Focus LX
    got to be honest mate, that looks awesome. much more imaginative than just sticking one on the dash with velcro. can see a few other people on here doing same thing.
    MIGWeb User IrmscherZafira's Avatar
    Nov 2003
    Staffordshire
    Irmscher Styled Zafi
    Very nice job, quite innovative too. Well done
    Since turning 30 I've become a grumpy old f*rt, for this I apologise
    Mig Club Member Orange Peel's Avatar
    May 2003
    Nottingham
    Great idea and design mate
    Nice to see a good clean functional mod
    lee may
    Guest
    So does it fold away so yopu cant see it?
    Looks cool
    Aug 2004
    Thanks for the comments.
    Yes, it folds away completely out of site of any prying eyes
    Nov 2003
    Staffordshire
    I know I've posted already but it really is impressive! good to see something different that works well and looks as good as that!
    MIGWeb User Scott G's Avatar
    May 2001
    57.37810N 2.08020W
    Honda Civic Typ
    Impressive.
    very AndyMk3Astra ish type work.
    My ex Mk3 Astra - My Corsa Sport - Join MIG Club ONLINE Here!
    "A wise man know everything, a clever man knows everyone"
    MIGWeb User GSi-R's Avatar
    Feb 2002
    Kuopio, Finland
    Oil burner
    Been a pleasure to read this thread. Well done for the determination to achive what you wanted. Excellent result. Bet your chuffed.
    Like the footwell lights too
    Aug 2001
    out there!!!
    modified zafira
    that is realy trick! my hat's off to you. nice bit on info in this thread for anyone else wanting to do the same. a proper job!
    May 2002
    Basildon, Essex
    Mk3 Astra (again)
    That is amazing...
    well done, a lot of effort went into that, and it paid off well
    VXR Vectra
    Apr 2004
    Derbyshire
    Calibra V6 again :)
    u gonna start selling them? bet a few on here would buy one
    Aug 2004
    Again Thanks for the comments guys!
    Oakey22, thats a good idea mate. Thing is, the monitor that i used, to buy new the cheapest ive seen is £170, and they hardly ever come up on ebay. I just got lucky when i spotted 2 for £100.
    Apr 2001
    Norwich
    M3, 200sx, RWD Nova
    I can see Next having a surge of sales of men buying Nail Care boxes!! lmao
    Excellent work mate. Truley excellent.
    Simps.
    Dec 2004
    Colchester,Essex
    PuntoGt|AstraGte16v
    Astra Gte 16v
    |Any Paint and Bodywork advice needed pm me|
    Jun 2004
    Kings Lynn, Norfolk,
    2.0 Cav SRi
    Some nice work gone into that
    Doesn't it seem a bit low though when you're looking at it? Especially if you want to use it for GPS
    Leo
    Team TalkAudio Member
    Aug 2004
    Hey Leo,
    Im pretty happy with the position to be honest, though i agree, with sat nav it would be a bit low. However i plan on buying a sat nav unit with voice directions as well as a visual. I might also get a reverse camera for the hell of it
    Jan 2005
    Leicester
    vwpisshat/Series IIA
    Very tidy! i need to think of somewhere to cleverly stash a screen in my 'bra
    May 2004
    Poole, Dorset
    looks great mate,
    footwell lights, i use 12" blue cold cathodes
    Dom
    Dom is offline
    MIGClub Member Dom's Avatar
    Sep 2001
    Northants
    73bhp MK4 Astra POS
    Nice one - looks good.
    Just wait for the first drunk mate to try putting a fag out on it though lmao lmao lmao
    Gal
    Gal is offline
    Sep 2003
    London, United Kingdom,
    There and back
    I'm glad that worked!! Bet plenty of people are now going to give up smoking just so they can fit a screen!!!
    My hand to Japs eye co-ordination is great!!!
    Aug 2004
    LOL, I hadnt thought about that! lmao
    I operate a smoking ban in my car anyway, so should be ok..
    Bet plenty of people are now going give up smoking just so they can fit a screen!!!
    LOL, NHS my arse!
    Sep 2002
    Souwf London
    Champion Turbo
    Matt, what are the Dimentions of that monitor, I've always fancied adapting one to the cassette holder in the Mk2, but never thought you could get one small enough!!!
    I've forgotten what a cassette even looks like now........
    Aug 2004
    Hey Ronin,
    monitor dimensions are:
    174(W) x 127(H) x 27(D) mm
    I have another exactly the same here, which i might sell soon if your interested.
  26. #25
    MIGWeb User TomH's Avatar
    Cheshire
    MK5 Astra 888
    thats ace nice one
    888 CDTI 194bhp 304lbft - 074/100
    Awesome GTI - 03/11/07
