I have an amp that has four channels, two of which can be set to low pass filter and two which can be set to high pass filter. Or they can be both set to use no filter. I want to convert the two channels which can use high pass filter to low pass. so I can use all four channels for subs (bridging them). Can I buy a low pass filter thing that I can put between the amp speaker out and the sub that'll only let low frequencys through (40hz). Where can I get such a device from and likely cost?
