cobra alarm
Results 1 to 25 of 25
Thread: cobra alarm
    Apr 2003
    chesterfield
    vecky sri
    cobra alarm
    i bought a new car and its got a cobra alarm and immob
    just wondered if anyone has a manual or any info on it
    i have attached picture below of fob and immob key
    at the moment when i arm it its silent can it be altered to chirp
    and if i arm it and press second button it makes a high pitched beep
    whats that mean?
    any info please thank you all
    vecky sri
    Apr 2003
    chesterfield
    vecky sri
    bttt
    vecky sri
    Feb 2001
    Edinburgh.
    Vectra GSI
    They should be able to chirp no problem. If you press the second button after the first (within about 30 seconds) it disables the internal ultrasonics, in case ou have a dog or summat in it. If you press it when the alarm is disarmed it usually acts as a panic alarm and sets it off immeadiately.
    CHAMELEON
    Apr 2003
    chesterfield
    vecky sri
    any idea how to make it chirp on arming and disarming
    cheers for your info
    vecky sri
    Apr 2003
    chesterfield
    vecky sri
    still not figured it out yet how to make it chirp
    i have just tried pressing the second button while ignition was on and it made a long high pitched noise and led flashing
    ooopps what have i done
    vecky sri
    Feb 2001
    Edinburgh.
    Vectra GSI
    not to worry, thats just the panic alarm (bet you did too!) If you get hijacked or summat.
    Best bet for the chirp is to talk to a proper alarm fitter who shouldbe able to tell you if and how you can do it. It is probably a dip switch on the control unit. DO NOT MESS WITH THESE IF THEY ARE THERE!!!!!!!
    CHAMELEON
    Jul 2000
    find the control unit and flick about with the switches
    Apr 2003
    chesterfield
    vecky sri
    thanks for info guys
    vecky sri
    Feb 2003
    Kings Lynn, Norfolk
    Signum3.2,Vectra SRi
    i think i have the same alarm on mine, i'll have a word with a mate on mine (alarm installer who fitted it)
    There is a programming mode you can go into where you can tell it how loud to chirp.
    Think its something like leave the bonnet and drivers door open then enter you pin code on the button (button is on the light that flashes) think default code it press once.. wait for one flash then press once more (do this so the code you enter is 1,1,1,1= cobra default)
    for all of these modes to work each sensor wire must be connected to the correct sensor.
    I'll try to get more info.
    Signum Elite 3.2v6 now replacing the old Omega MV6 Estate 3.0v6
    Feb 2003
    Kings Lynn, Norfolk
    Update.....
    Right spoken to him so here goes...
    Open bonnet and drivers door.
    Ignition on.
    Press and hold big remote button till indicators flash then release button.
    keep pressing the big button to turn beep volume up and small button to turn volume down.
    When you get in to the level you want shut the bonnet, indicators should flash for approx five secs.
    Then ignition off.
    It should now be set to the volume you selected.
    ok?
    Apr 2003
    chesterfield
    vecky sri
    Re: Update.....
    Ignition on.
    Then ignition off.
    ok?
    cheers i owe ya 1
    i will give it a try in morning
    i will let you know if it worked
    sorry for not replying i have had troubles getting on mig web
    vecky sri
    Apr 2003
    chesterfield
    vecky sri
    has any one got a manual for the cobra 7925
    im mainly after the chart with all the programming on
    there is a few changes i want to make to my alarm
    ie auto re arm
    passive arming
    etc
    cheers for any help you can give me
    vecky sri
    Apr 2003
    chesterfield
    vecky sri
    i tried the trick with bonnet and door open and hazards dont flash nothing happens ?
    cheers any ways
    vecky sri
    Aug 2002
    Northwest
    SRi-T, Corsa-T
    what model cobra is it ? click this link for info on the 7928 one :
    Cobra 7928 Alarm
    Apr 2003
    chesterfield
    vecky sri
    Cobra 7928 Alarm
    its the 7925 model i will look on link now chweers
    vecky sri
    Apr 2003
    chesterfield
    vecky sri
    Cobra 7928 Alarm
    no there isnt anything on it about chirp or passive arming etc
    cheers for trying anyways
    vecky sri
    Apr 2003
    chesterfield
    vecky sri
    still needing help on alarm
    vecky sri
    Feb 2003
    Kings Lynn, Norfolk
    my mate the alarm fitter said all cobras are the same to program, try the way i said before and make sure you follow it to the letter!
    Feb 2001
    Edinburgh.
    Vectra GSI
    Just make sure you aint got a dicky bonnet switch like mine.
    CHAMELEON
    Apr 2003
    chesterfield
    vecky sri
    ok i will have another bash tomorrow i will check bonnet catch too
    cheers
    vecky sri
    Apr 2003
    chesterfield
    vecky sri
    right, this is what i did
    i checked bonnet switch and is working fine,i tested it by opening bonnet and trying to set alarm and it gave a long beep to say something is open.
    so i left it open and opened the drivers door and switched ignition on and held big button on remote for ages and ages and no indicators flashed?
    i tried several things and the only thing i have come up with is
    if i turn ignition on and off 3 times the led inside flashes but still doesnt do anything on the big button?
    any other help any one?
    vecky sri
    Mar 2005
    also looking for help
    im also looking for help on this alarm anyone got any links or info on setting damn fing up ????? i think mines stuck in valet mode also i cant get windows to react to alarm i have the 7928 with 7926 and 1984 cobra conbined please any help would be great TIA
    May 2010
    Re: cobra alarm
    just wondered if anyone has a manual or any info on Cobra 7926
    whats that mean?
    Nottingham near Ikea
    Vectra ST200 #0005
    Re: cobra alarm
    trigger123 I have a Cobra alarm and manual so I'll dig it out and scan the bit you need, drop me a PM as a reminder though as I know I'll forget. Is it the round remote fob you have the green (ish) buttons, one big one small?
  26. #25
    May 2010
    Re: cobra alarm
    Hi Harvey
    Thank you very much for your help, I didn't get you, what does PM means?
