oil cooler in the inner wing?
Results 1 to 7 of 7
Thread: oil cooler in the inner wing?
    Jan 2002
    southampton
    sm2'd, T3'd let nova
    just a thought!,
    i know its easy enuff to run the oil cooler on my let nova infront of the rad but would it be ok to run it in the inner wing?
    as a m8s dad said this is where all the saabs route theres to as the wheel provides a gud air flow?
    [quote]The Simps;
    If you find the water leak and its a hole that needs welding up gimme a shout[QUOTE]
    Jul 2000
    Manchester
    Vectra/Sunbeam/Nova
    err how?
    unless you had a hole in the bumper and were prepared to get it covered in crap
    Jan 2002
    southampton
    Thread Starter
    inner wing as in when suspension sits etc! why would that nd a hole etclmao
    [quote]The Simps;
  5. Remove Advertisements
    Jul 2000
    Manchester
    Vectra/Sunbeam/Nova
    i thought you ment the inner arch as where the wheel sits
    would probably work if you could get deacent airflow through it
  7. #5
    Dec 2002
    Blackpool
    Frontie V6/2 x MR2s
    You need to work out the air flow ie. where are the high and low pressure regions around the wing/wheelarch, and ensure that you can get sufficient airflow through the cooler. Don't forget that you'll also need to protect it from stones etc. thrown up by the wheel.
    "Lately, the only thing keeping me from being a serial killer is my distaste for manual labor."
    - Dilbert
  8. #6
    Sep 2002
    BRISTOL
    Vectra GSI 2.6 V6
    y not just mount it in front of the radiator, surely thats the best place for airflow, seems a lot of work for not any real benefit
    Vectra GSI 2.6 V6 - Completly showroom standard..... Minters
  9. #7
    Dec 2002
    Blackpool
    Frontie V6/2 x MR2s
    Front mounting the oil cooler means that by the time the air gets to the radiator its already warmed up, especially if you have aircon too ( and a FMIC in some cases as well ). If you can get a separate air feed ( eg from a scoop in a front spoiler, ducted to the oil cooler, then exhausted into the wheelarch ) you will reduce the underbonnet temp a little.
    Hows this for an idea - oil cooler in one wing, intercooler in the otherlmao
    - Dilbert
