Cav SRI 130 Conversion into 1.8 Manta B "How to'
Results 1 to 16 of 16
Thread: Cav SRI 130 Conversion into 1.8 Manta B "How to'
    Aug 2003
    Newport- South Wales
    Shexy modified Manta
    Lightbulb Cav SRI 130 Conversion into 1.8 Manta B "How to'
    "I haven't done this conversion yet but for anyone looking to do it here is the "how to":
    Click here to see the "SRI 130 > 1.8 manta How to"
    The 8 valve is a breeze to fit.
    All the 1.8 parts can be used including the
    viscous fan,
    all the bolt holes are there on the block for everything,
    including the 1.8 dizzy drive (bolt holes on the cam cover)
    Sump,
    exhaust,
    g/box in fact everything is a straight bolt on.
    Fiddley bits......
    Water hoses, it is possible to cobble together the existing water hoses to fit the SEH using the two small carb pipes to go to the SEH throttle housing by using a straight connector and some extra hose.
    Other fiddly bit was a mounting bracket for the air flow meter. (email sales@cutomsolutions.me.uk ) he can supply a suitable custom made mounting bracket at a ridiculous (cheap) price
    The worst fiddly bit was extending the loom so the ECU fits in the drivers footwell.
    The loom is very simple too.
    it is all self contained and like me you will have to fit high pressure fuel lines (I used rubber items for ease of fitting and the fact they won't rust with something stupid like 100 BAR burst pressure)
    Make sure the Hones are bored if fitting new rings
    Also you will need an injection tank, not a problem to source one of these for the coupe, max price 15 is what I would expect to pay and of course you will have to fit a fuel pump, again not too much of a problem
    Clutch...... I used a 1990 2.0i Carlton clutch pressure plate and release bearing.
    Bolt on your 2.0i ohc Carlton Clutch,
    your 1.8 box,
    your 1.8 dizzy drive and timing cover,
    swap the sumps over,
    bolt on your 1.8 engine mounts,
    OH I think you need to swap the oil pick up pipes too.
    If you want to retain the viscous coupled fan, there are bolt holes on the Sri Block for this too.
    Cobble up your water hoses,
    wire it up,
    bolt it in
    and start it up.
    Nothing to it........
    Also had some head work done on my engine
    For a cheap and very simple conversion you cannot get better. I was talking to Chris Cotteril at the AGM on Sunday he told me he was getting 160 bhp from his old 8 valve SEH.
    Of all the jobs, I think I hated fitting the fuel lines the most.
    And trying to solder the wires on the extended loom on a windy day (soldering iron didn't keep hot enough)
    Don't let the fact that the sri 130 is a FWD car enter into your head.
    Basically all you are doing is turning the sri engine round 90 degrees to mate up with the 1.8 Manta gearbox.
    "EVERYTHING" off of the 1.8 will bolt onto the 130 engine
    But you may find the SRi 130 alternator to be a tad higher in the amps output department than your 1.8
    . On the SRi engine you will find 3 (i think) engine mounts (throw theses away) and a load of water pipes bolted onto the block, throw these out of harms way but hang on to them in case you want to cobble some pipes up later.
    dont forget to fit a spiggot bearing into the end of the crank or youll knacker your imput shaft on the gearbox
    What made the SRi 130 quicker than a standard SRi?
    2 Bhp more than Astra GTE 2.0L due to better exhaust route
    Revised Bosch Motronic Engine Management
    Larger Intake valves & exhaust manifold
    More compact combustion chamber shape
    Bigger bore exhaust along the length
    Shorter, lighter Pistons
    Revised valve timing
    Integrated, adaptive engine management & ignition system
    Engine block both stiffer & lighter
    Crank & con rods lightened
    Friction loss cut by thinner piston rings & valve stems
    New high efficiency oil pump & cooler in front grille.
    Smaller water jacket for quicker warm up & enhanced pump.
    Standard: 130Bhp @ 5600 &133lb ft @ 4600 rpm 0-60 circa 8s
    please DrIvE slowly
    Aug 2003
    Thread Starter
    Unhappy
    Gotta admit, not a clue what all that translates to. obviously some of it but "0-60 circa 8s"???
    anyone know what it all means?
    please DrIvE slowly
    Aug 2003
    Thread Starter
    What have i missed out?
    One thing i can remember is:
    "dont forget to fit a spiggot bearing into the end of the crank or youll knacker your imput shaft on the gearbox"
    But the only other thing i'm unsure about is the ECU!!
    Can I use the ECU from the 1.8 manta with this engine? I mean just until I can find one from a cav SRI 130. Will it run with it?
    please DrIvE slowly
  5. Remove Advertisements
    nrj
    nrj is offline
    Nov 2002
    Hampshire
    Not a Vxl
    no, 130 uses a completly different ecu map, don't forget mk3 cav sri's had this engine in, there millions of these being broken
    CAR FOR SALE: Vauxhall Zafira
    BREAKING: Yellow Pug 306 Convertible
    WANTED: Downhill Mountain Bike
  7. #5
    Jun 2002
    up north
    Girlfriend crazy
    The 1.8 manta had a carb. The closet thing to an ECU was the radio.
  8. #6
    Aug 2003
    Thread Starter
    hehe - like that. stupid when i think about it. Dunno y i didnt realise that Think i need more coffee (beer will do fine)
    please DrIvE slowly
  9. #7
    Aug 2003
    Thread Starter
    please DrIvE slowly
  10. #8
    nrj
    nrj is offline
    Nov 2002
    Hampshire
    Not a Vxl
    didnt read it properly thought he had 'i' in place when asking about ECU swaps
  11. #9
    Northeast Kent
    circa means "near enough", or "around", 8s is 8 seconds.
    it accelerates from standstill to 60 miles an hour in "around" 8 seconds.
  12. #10
    Aug 2003
    Thread Starter
    Could someone offer some advice on how to extend/wire up the ecu before i take on the job. From what i've heard it's a pig of a job to do. Does that just mean it's very fiddly and time consuming or does that mean it's very difficult and complicated.
    That's the only thing i haven't managed to find out about - whats involved with the ecu.
    appreciate it - gonna be a big help when i start doing the engine soon as i get my engine hoist fixed and come to the ecu.
    does anyone have an ecu, i've looked on eBay, and at my local scrap yards. Only thing i haven't ran a search yet on is this forum (gonna do that now).
    What will work?
    SRI 130 (obviously)
    mk3 cav sri
    _________?
    cheers ya'll
    please DrIvE slowly
  13. #11
    Nov 2000
    St. Asaph, N. Wales
    Nova, Audi, Landrover
    someone posted a pic of a 130 ecu the other day asking what it was... rgb?
    LEE69
  14. #12
    Aug 2003
    Thread Starter
    Cheers, just tried to find it - Is this it :
    What is this on ebay??
    That "Fuel Injection ECU Vauxhall Astra GTE 1.8"
    Anyone know wether that would work? I don't think it would work would it? Anyone confirm that cause i'm not sure.
    please DrIvE slowly
  15. #13
    Aug 2003
    Thread Starter
    oh yea - Fuel Tank/Pump?
    Does this have to be from a cav SRI. I mean does the operation of it differ from any other vauxhall (injection) fuel tank & pump.
    The sri 130 engine is multi point injection. does it matter.
    Just theirs alot more fuel tanks/pumps available at my scrap yard from other cars like fuel injected 1.4 astras / 1.8 Cavaliers and other vauxhalls.
    What fuel tank/pump will work? I'm not sure but i'm probably gonna have to modify it to fit where the 1.8 tank used to be. Not a problem cause i can easily drill out new holes and put the bracket that wraps over it back on. Just is their any difference in the mechanics/operation of an SRI tank/pump to any other cav/astra?
    please DrIvE slowly
  16. #14
    Nov 2000
    St. Asaph, N. Wales
    LEE69
  17. #15
    Jun 2002
    up north
    Girlfriend crazy
    Have a look on the Opel Manta Owners Club forums. There was an explanation there recently. Use the tank from a GT/E coupe as it has a swirl pot inside and the return line. Get the pump bracketry whilst you're at it. I've often wondered if the loom from a carlton would work. Friends with the 130 engine have put the brain in the passenger footwell so the loom is long enough.
  18. #16
    Aug 2003
    Thread Starter
    Ta, big help - appreciate it. Let's hope he doesn't want to much for it considering he doesn't know if it def def works.
    What's a good price to pay? I was hoping to pick one up for free from someone who doesn't need theirs (very skint) but have a little bit of money coming in next sunday.
    I've seen them go for a couple quid and at the scrappy for a non sri ecu they only want a couple quid (loads of scrappied round ere.
    please DrIvE slowly
