How do I get around the drive shaft problem? Can I use a Astra Cavalier combo to fit the Nova hubs. Bearing in mind that I have an early xe will I get away with sawing off the power steering pully and using a hammer to make room in the engine bay for the alternator to fit the Nova engine bay .
for the driveshafts you can use cavvy mk2 1600 big block inner cv's and you're nova shafts, as for the alternater a hammer will do, yes, and the bottom pulley idea will be ok too
I'm still using that driveshaft setup on my LET Nova (standard power) with no problems so far.
