After listening to the gearbox yesterday (naughty Davo) it really needs that 3rd gear syncro. However, since its coming apart I wanted to do 1st and 2nd as well and then thought that I might as well do all 7.
There is more than just the syncro's to overhall though isn't there? The gearbox has 110k on it and I'm sure for some of that its been thrown about a bit. I doubt there is much point in replacing the gears themselves but are there other parts such as bearings that should be replaced?
So, bascially the question is what can be replaced on the gearbox? Excluding silly things like the casing.
Also, since this is going to cost quite a bit, is there a realistic upgrade from the F28? I don't want to use a straight cut 4 speed or anything like that because I like the cruising but I thought I'd ask
