EDS phase 2 boost
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 32
Thread: EDS phase 2 boost
    Northeast Kent
    EDS phase 2 boost
    am i right in thinking its 1.5 over, 1.2 steady ?
    Sep 2001
    Sheffield
    Mk2 Astra Estate
    yup
    RDS
    RDS is offline
    Jun 2001
    Plymouth
    Veccy 3.0 24v Diesel
    1.5 bar overboost and 1 bar steady
    Sir, please step away from the car
  5. Remove Advertisements
    Nov 2000
    Woking, Surrey
    GTE 16v Turbo
    Re: EDS phase 2 boost
    1.5 and 1.15 is Phase 3. Thats probably what you were thinking of.
    Contemplating lots of things
    Astra GTE Turbo - Link Now Working
  7. #5
    Northeast Kent
    Thread Starter
    ok, well its boosting as standard .8 over, .6 steady.
    now the dilemma, do we adjust the actuator and forefit the warranty (blue security paint)
  8. #6
    Apr 2002
    at pub when offline.
    GTE 16V mk2 + Cav T
    So the cars got phase 2 fitted but is only making std boost?
    Prolly worth giving em a ring first before adjusting actuator innit, that way if they say yes do it no warranty issues.
    Does it not make any difference changing position on power switch?
    Quote from specialist Ford engine builder -
    "Wish it was Ford that built the XE...thats one great engine..."
  9. #7
    Apr 2002
    GTE 16V mk2 + Cav T
    If you are gonna adjust actuator then just nip out and get a touch up of same colour paint, theyll never know
    unless theyve read this post and put names to faces
  10. #8
    Northeast Kent
    Thread Starter
    yah, phase 2 fitted, and making same boost as standard, but the turbo is just back from being reconned (blue tamper paint)
    there is no power switch, i presume you mean a power wheel boost adjuster thing ? not fitted.
  11. #9
    Jan 2003
    Near Manchester
    BMW 120 M Sport
    Hi folks,
    Iv just fitted phase II chips to my cav. I do not have the i/c or fp regulator. Shall i run it at phase 1 boost??
    If so what should it do??? in psi??
    18psi over 14psi??
    Cheers for the help
    James
  12. #10
    Northeast Kent
    Thread Starter
    just barge in, why dont you.
  13. #11
    May 2002
    Mansfield
    Calibra Turbo
    New phase 2 comes with a switch, standard or phase 2 boost levels.
    If your phase 2 is new it should need a switch, with no switch fitted it MAY run standard boost not phase 2 boost levels and adjusting the actuator will nothing.
  14. #12
    Aug 2002
    kent
    On route 2 a GT-R
    Originally posted by JamesR
    Hi folks,
    18psi over 14psi??
    Cheers for the help
    James
    well that wont last long then if i was u i'll get an fmic and 3.5 fpr or, just use yr standard chips, otherwise it's gonna go pop very soon
    u cant c chuck norris, but he can c u,if u can see chuck norris then yr only seconds away from death.
  15. #13
    RDS
    RDS is offline
    Jun 2001
    Plymouth
    lol the actuator has to be adjusted to attain the extra overboost, the standard actuator is indeed only set for normal power.
    A stronger actuator is a better way to go as it puts less strain on the wastegate as it holds boost with less resistance The only way to get more boost currently is to adjust the actuator.
    I used phase 2 chips from Gavin Wallace without the power wheel and had no problems at all for 40,000miles, i did actually buy a stronger actuator in the end which worked really well
  16. #14
    Feb 2002
    West Yorks
    Vectra 3.2 GSI
    JamesR
    i think running your car at phase 1 boost will be fine...
    just take it steady till you get the fmic and fpr...
    Oddball
    as rds says you will have to wind up the actuator to get more overboost!
  17. #15
    Dec 2002
    London
    R32 GTR, BMW 520D E60
    Re: Re: EDS phase 2 boost
    mine was boosting at 1.4 over boost and 1.05 bar held...
    www.endless-sport.net
  18. #16
    May 2002
    Mansfield
    Calibra Turbo
    Obviously but the amount of boost the actuator see's is controled by the amal valve which in turn is controlled by the ecu.
    What i was trying to say was the actuator may already be adjusted correctly but the ecu is running in "standard" mode.
    Without a switch connected do they run in permanent phase 2 or standard mode??
  19. #17
    Feb 2002
    West Yorks
    Vectra 3.2 GSI
    without the switch i think it'll run phase 2 power...
    as i have a phase one chips and i didn't bother with the switch and it is running 250 bhp
    hth
  20. #18
    Dec 2002
    London
    u need the switch or else wont run high power mode the eprom contains the high power map activation code...
    believe me i tried both with and with out when i had my p2..also got this confirmed by arno
  21. #19
    May 2002
    Mansfield
    Calibra Turbo
    Thanks Yunis
  22. #20
    Feb 2002
    West Yorks
    Vectra 3.2 GSI
    so are the phase 1 chips different?
    i.e. i dont have the switch fitted but am getting 18.5 psi over boost?
  23. #21
    Northeast Kent
    Thread Starter
    so whats the gen on this switch? dont tell me the ecu has to come off again, its such a fecking arse.
  24. #22
    May 2002
    Mansfield
    Calibra Turbo
    I think it depends on the age of you kit, the switch is a newish thing for phase 1 and 2 but was standard for 3/3.5.
    Ask your supplier.
  25. #23
    Northeast Kent
    Thread Starter
    RDS is the flippin supplier !!
  26. #24
    May 2002
    Mansfield
    Calibra Turbo
    If its Robs old phase 2 then prob dont need it. He's had phase 3.5 and 4 since then.
  27. #25
    Northeast Kent
    Thread Starter
    also, how does the ECU control the amal valve control the actuator when the boost is exceding 1 bar ? i thought the motronic only had capacity to quantify up to 1 bar ?
