Headlight Bulbs
Results 1 to 2 of 2
Thread: Headlight Bulbs
    Nov 2000
    Reading, Berkshire
    1380 Mini and Focus
    Headlight Bulbs
    Last night I replaced the bulbs H4 headlight bulbs in my cav Gsi because the headlights looked a bit dim.
    When I removed the existing bulbs I noticed one was a 90/100 watt and one was an 80/100 watt (both of which I think are illegal for road use).
    I replaced them with some standard Phillips 55/60 watt bulbs.
    The lower wattage bulbs are considerably brighter than the old higher wattage ones. Why would that be???
    Dom is offline
    MIGWeb Moderator Dom's Avatar
    Sep 2001
    73bhp MK4 Astra POS
    Could be a couple of reasons :
    Headlight bulbs can get dimmer with age - especially the high powered ones. The extra heat can discolour the glass over time leading to reduced light output.
    More likely - the extra current drain from the higher powered bulbs causes a higher voltage drop in the cable feeding them - double the wattage and double the voltage drop. Its pretty typical to lose up to 2-3 volts in the wiring to the bulbs with normal wattage bulbs - put a 100 watt bulb in and you're almost down to half voltage with some wiring.
    I run Osram Silverstar bulbs in the missus fiesta (55/60 watts) and they are much brighter than the standard 55/60 watt bulbs in the cavalier. This is due to the increased xenon gas in the bulb causing the bulbs to glow a lot brighter.
