Screaming Fuel Pump
Results 1 to 21 of 21
Thread: Screaming Fuel Pump
    Aug 2001
    Location Location
    Audi
    Screaming Fuel Pump
    After having got the car up and running on Sunday morning I decided to drive along to the S.E. meet and along the way my fuel pump started making a load whining / humming noise.
    This is accompanied by a massive fluctuation in fuel pressure withn the gauge reading second by second changes of 60 psi dropping to 40-50-60-30.
    I'm unsure whether its the fuel pump itself or anything else that may be causing it, i.e. relay or wiring.
    If I start the engine and test the voltage at the pump I assume I should get a constant reading. If I'm testing the pump and the voltage is fluctuating at the same time as the pump is whining then can I assume that it is related to the power the pump is receiving?
    I also want to rule out a crushed return line, if I disconnect the return line to the tank and feed it straight out the of FPR into a can then if the pump stops screaming I know this could be the cause.
    I know I could run wires straight from the battery to the pump but I am hard pushed to find any that are long enough and meaty enough. I suppose I could always disconnect the power line from the amp in the back and use the body as an earth couldn't I?
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    sounds like the pump is running dry for some reason to me, thats when they get noisy, using the amps live will work though to test it
    Oct 2001
    Stoke
    Nova. Sri 1.6 16v TBs
    either pump not getting a constant petrol flow or......
    not sure but what rgulates the 12v output from the relay? i know sometimes alts send out too much voltage when the regulator goes, could this send a higher voltage to the pump?
  5. Remove Advertisements
    Northeast Kent
    dicko has a good point there, because rob has had to actually wire up his own fuel pump relay, this is a throttle body install.
  7. #5
    Aug 2001
    Location Location
    Audi
    Thread Starter
    The relay has the following connections, +'ve (straight from the battery), negative (from the DTA ECU - switched earth) and the feed to the fuel pump.
    I did notice that the relay was incredibly hot, pretty much too hot to touch.
  8. #6
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    what rating is the relay mate? sound like its a bit over worked
  9. #7
    Northeast Kent
    its a stock vauxhall XE relay.
    you didnt mention the switch positive, thats just to ignition yeh ?
  10. #8
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    maybe an earth prob then? either on the pump or the relay itself? have read o the dta forum that its agood idea to earth the ecu casing seperatly aswell as the loom earth you get
  11. #9
    Aug 2001
    Location Location
    Audi
    Thread Starter
    I dont think there is a switch ignition is there? I think it switches through the DTA earth.
    (I'm not sure but will double check tonight)
  12. #10
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    yup, just uses the dta to switch the relay
  13. #11
    Aug 2001
    Location Location
    Audi
    Thread Starter
    coolio
  14. #12
    Northeast Kent
    it has a switch positive too, remember the pump and or the engine ran all the time when we first wired it up, even with the ignition keys taken out.
  15. #13
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    shouldnt need a switched live though, should be able to work purely off the switched earth from the ecu, maybe its the vaux fuelpump relay, could you not jst use a normal five pin relay?
  16. #14
    Aug 2001
    Location Location
    Audi
    Thread Starter
    Well it looks like I've got to the bottom of it.
    The problem stems from a bracket I made for the FPR. Basically due to the FPR's position on the bracket the fuel line out of the return end of the rail had a sharp bend in it. It wasn't kinked but it was far from "straight through". Therefore I reckon the pressure would build up in the line and force some through to the FPR while putting additional strain on the pump.
    BTW I checked the relay there is definately no switched +'ve, only a switched earth and the relay is off when the ignition is off.
  17. #15
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    been out in it yet? fully sorted? isnt it nice when you fix something for free!
  18. #16
    Aug 2001
    Location Location
    Audi
    Thread Starter
    I've been out for a test drive and taken all the way to 7750rpm seems fully sorted, no whining, no loss of power, sits at 60psi.
    Indeed, fixing a problem for free almost makes up for all the overpriced items you buy time to time.
  19. #17
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    could do with some of that right now i can tell ya! glad you got it sorted, btw was that full throttle all the way to 7750?
  20. #18
    Aug 2001
    Location Location
    Audi
    Thread Starter
    lmao it suuuuuuuuurrre was partner.
    You'll get it sorted Lee, what state was the engine in?
    I should be going to see Steve Greenalds soon.
  21. #19
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    ts all but cut up now matey! engine is yet to be opened up, but the cam belt has jumped a few teeth so fingers crossed, think i'll be ok though as omegas have mighty deep pockets in the pistons, gonna do the head while its out, oh and solid lifters
    havent told steveg yet, i'll have to mail him some pics, let me know how you get on down there mate
  22. #20
    Aug 2001
    Location Location
    Audi
    Thread Starter
    Will do, no problem. I might mention it too him when I see him.
  23. #21
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
