A friend of mine is currently in the process of building DTA on his manta.
The current map which is loaded into the DTA is to aggressive ( according to him the map was for a 200 HP c20xe engine. )
Does someone have a standard c20xe mapping on which the car will run. Setting the DTA system on the dyno will be done later.
