turbo issues.
Results 1 to 22 of 22
Thread: turbo issues.
    Jun 2000
    Deep West Wales
    Subaru Legacy GT-B
    turbo issues.
    All.
    Firstly, very new to the Calibra Turbo so bare with me If I'm a little dim.
    * Firstly, it seems to only be boosting at around 4.5K which causes it fly round to 7K quicker than last nights curry leaving the body.....
    Is this normal as I thought the boost would kick in a lot earlier than this, though it does seem to kick in lower in 3,4,5 & 6..... as I say above, is this normal.
    * Also, I am getting two warning lights on constant, No.1 - its the radiator type looking one on the left of the display. The car runs at about 60-90 deg, unless left standing or "used" hard, though under the hood it feels VERY Hot...
    No.2 - The abs light, though the pads are fairly low so I suspect this is the cause....Thoughts.
    * Finally for now....
    What tyres would be best suited to the 4x4, I have read about keeping them all the same design & tread depth. What are you recommondations.
    Thanks in advance.
    regs
    Bobby
    Banned
    Mar 2003
    Turbo Country!!
    A Nissan and a Vaux
    any tyres that u like... better the brand.. safer youll be
    make sure u get x4 of any tyre u choose.. or pop *boom* goes your 4x4 system.. quite simply
    if u have a blow out...
    tuff.. u gotta get x4 new tyres
    if u park badly and gouge a hole in the side wall of ya tyre...
    tuff.. u gotta get x4 new un's...
    if theres more than -2mm tread diff between the front and rear tyres... POP goes ya 4x4...
    so keep rotating your tyres x3 times a day to keep it safe
    HTH
    Oct 2001
    Kent
    the car in front
    You may find my website interesting
  5. Remove Advertisements
    Jun 2000
    Deep West Wales
    Subaru Legacy GT-B
    Thread Starter
    So.....3 x a day for tyres, I knew the Transfer box was delicate. but dammmmmmm.... Well it had a new Transfer box fitted 8K ago so I'm hoping it should be cool, the tyres are different brands though, it has F1's on the front & a Firestone Directionial on the back...Though they are the same'ish depth, I will get all 4 changed for piece of mind.
    John, great site mate...... Will prob get the sack today for mis'use of the internet..
    So what are you thoughts on the probs I'm having.
    Regs
    Bobby
  7. #5
    Nov 2000
    Woking, Surrey
    GTE 16v Turbo
    Re: turbo issues.
    The pads being low won't cause the ABS to come on, its probably a faulty sender.
    Contemplating lots of things
    Astra GTE Turbo - Link Now Working
  8. #6
    Jun 2000
    Deep West Wales
    Subaru Legacy GT-B
    Thread Starter
    Arrrr...right, okay mate....Thx
    Is this a common prob then....the brakes are okay, well they stop me, lucky enough I aint had to check the abs out yet...not properly any way.
    Thx again..... So what is this other light on the dash then....
    regs
    Bobby
  9. #7
    Northeast Kent
    the turbo spins up before 4.5k, but theres a massive extremely sharp application of torque at 4k ish, which may give the impression theres nothing below that.
    turbo apearing to kick in lower than 4k in high gears is normal too, more load on the engine see.
    radiator warning light, thats just low fluid level in the expansion tank isnt it ? if the tank is half full of liquid then the floats proably sunk.
  10. #8
    Nov 2000
    Woking, Surrey
    GTE 16v Turbo
    I'm not sure but it might be low coolant. Is it orange?
    Obviously, fill the coolant up to the max line. There is a sensor in the side of the container, it may of come off or be faulty or something which is causing the light.
    As long as there is coolant don't worry about it.
    ABS sensors are not cheap at all but you can take the sensor and bracket off another car and use them. DO NOT try and remove the sensor from its little bracket, it absolutley will not come out...ever.
    Have you considered moving the engine to a RHD shell? Shells tend to be very cheap what with people removing C20LET's for Astras and Nova's.
  11. #9
    Jun 2000
    Deep West Wales
    Subaru Legacy GT-B
    Thread Starter
    Cheers OB. I had already checked that, so if that is what it is for it must be a wiring or sensor prob...Good man, thanks, I just needed clarification that the symbol does refer to the expansion tank.
    Many thanks.
    regs
  12. #10
    May 2002
    Rainham, Kent, UK
    Corsa VXR
    the legal issues on removing the tyres and putting them back on the rims is getting tougher due to tyre blow outs and insurance claimes. Theres a good chance your tyres are directional ones, so you have to flip the tyre round so it wears on the other side of the tyre, hence remove it from the rim. I had to go to a small local garage, cash in hand, for him to swap the tyres over. The bigger places like Kwick-fit won't touch them, unless you are putting new tyres on. Once a tyre is removed its classed as '2nd hand' and they won't refit them to a rim due to insurance reasons.
    depeding on year, you can read out the ABS fault codes for free with a paper clip, see my tech info pages on my site at www.topbuzz.co.uk
  13. #11
    Oct 2001
    Kent
    the car in front
    Originally posted by Topbuzz
    ...claimes. Theres a good chance your tyres are directional ones, so you have to flip the tyre round so it wears on the other side of the tyre, hence remove it from the rim. I had to go to a small local garage, cash in hand, for him to swap the tyres over. ...[/url]
    I don't get this Alan.
    My tyres are directional, so what? The front n/s tyre goes back n/s. Direction is the same, isn't it?
    You won't swap them diagonally, so what's the problem exactly?
  14. #12
    Jun 2000
    Deep West Wales
    Subaru Legacy GT-B
    Thread Starter
    Top Buzz. - I was refering to the water warning light, in my note "already checked that" so on the abs front you think it will be a sensor....I presume I have 4, one at each corner...Big job ahead then...Though I will have to drop all the wheels off anyway to get the tyres changed., will take a look at all the sensors, make sure everything is as it should be..Thx
    I'd love to reshell the car, but then I have all the extra hassles that come with that. Not sure yet as I think I can live with being on the left of the car.
    Thanks again.
    regs
    bobby
  15. #13
    cambridge
    Octavia VRS
    The wires on the header tank lid are very small and are easily broken, so check that. I expect its the cause of your low level water light if is is at the correct level.
  16. #14
    Northeast Kent
    youll have to get under the car for the rear abs sensors. they are on the inboard cv by the rear diff.
    the heads get covered in crap and dirt, its worth giving them a quick clean, including the teeth on the cv's, to see if that cures it.
  17. #15
    Apr 2002
    at pub when offline.
    GTE 16V mk2 + Cav T
    Think he was suggesting along the lines that a tyre does generally not wear evenly across the tread so swapping side to side as well as front to rear increases useable tyre life and makes for more even wear, but this does mean removing from rims and refitting, a right pain.
    Quote from specialist Ford engine builder -
    "Wish it was Ford that built the XE...thats one great engine..."
  18. #16
    Oct 2001
    Kent
    the car in front
    If the inside of the tyre wears differently to the outside, then you might have suspension/tracking/alignment issues mate - that won't help the tx box one bit!
  19. #17
    May 2002
    Rainham, Kent, UK
    Corsa VXR
    Exactly. A car sqarts down anyway, so the wear will never be even (more of a proablem with lowered cars), so one side of the tyre will wear down more than the other. To get a bit more life out of the tyre, you need remove the tyre, spin it round and refit, so the worn part is now pointing on the outside of the car.
  20. #18
    Oct 2001
    Kent
    the car in front
    These are problems expected from lowered cars with wide wheels etc - you take a hit for the sake of 'looks'
    I've never had anything like this on stock geometry with 205/50s.
    The previous tyres lasted 30K miles on mine, and had almost 4mm thread when I dumped them.
  21. #19
    Jun 2000
    Deep West Wales
    Subaru Legacy GT-B
    Thread Starter
    Present tyres are okay wear wise, but its the fact they are different so I will changing them all the weekend. Am I better to go for non directionals then, this way I can swap to any corner of the car can't I?
    I have another issue as the when car is hot, upon starting up the revs fluctuate for about 10 secs, down then up then leveling off. the Lump is the Ecotek Turbo (yellow spark plug cover) so do these still use a ICV or is this normal for this engine....After the initail few moments the car is sweeeet..as long as you dont touch the pedal. This only happens when hot, i.e. 90 degress +
    Again, thanks for your advice.
    regs
    bobby
  22. #20
    Oct 2001
    Kent
    the car in front
    Don't know if it's relevant at these temps, but there's a "hot-start valve" on the LET, at the top left of the throttle body.
    Is yours connected?
    Do you get this issue only when the engine is being started and it's very hot already?
  23. #21
    May 2002
    Rainham, Kent, UK
    Corsa VXR
    yes but you'll find the bigger the tyre and speed reading, the more likly they will be directional types.
    Sounds like the CTS, new is about 7 from autovaux or 20 from VX dealer, 5 min to change.
  24. #22
    Jun 2000
    Deep West Wales
    Subaru Legacy GT-B
    Thread Starter
    TB - Again.. Thx....
    Looks like vaux will be getting a big lump of my Wages this month, esp if I need to change some of the ABS sensors to....
    Thanks again
    Regs
    Bobby
