ok im putting a 1.4sr engine into my 1.2spi nova, the engine is in now im stuck with some of the wiring. 1st of all wot needs connecting to my webber carb, i no there's fuel return and inlet pipes from the fuel pump, a vacuum pipe and a positive feed for the auto choke (wot color is this feed?).
wot color wires need connecting to the starter motor?
wot color wires need connecting to the alternator?
wot other wiring needs connecting and to where and wot colors?
for the fuel pump ive just removed the injection relay and connected the pipes from the injection pump together is this correct?
i take it all the wires with fancy plug connecters can b removed as there part of the ecu system?
