throttle body progress
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 26 to 50 of 55
Thread: throttle body progress
  1. #26
    Oct 2001
    Stoke
    Nova. Sri 1.6 16v TBs
    Thread Starter
    will do
    got a works do so iv got 90mins to get it sorted + running.
    hmm or should i leave it for tomorrow
    Oct 2001
    Stoke
    Thread Starter
    well iv waited 4 days ands the fcukin retards have sent me the wrong size, and there miles too small.
    as seen as its the only seal on the fuel rail i really cant see how they have managed this!!!
    gonna resort to taking an extended lunch break tomorrow from work to visit a engineering place to get the right size. lets just hope my ecu aint screwed now!!
  4. #28
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    ah mate, what did they send? injector o rings? keepthe faith though mate, you'll get there
  5. Remove Advertisements
    Oct 2002
    Luton
    205gti
    Halfords do mixed bag of O-rings, there might be the right size in there???
    Or is that totally useless help??
    Hope it gets sorted.
    P.S do you all have out of tank GSi fuel pumps??
  7. #30
    Jun 2000
    Swindon
    yep I take that back - tapers have the injectors on the manifold
    8 injector setups are as notoriously difficult to get real extra power from as big valves - it's only on very high spec engines where the extra power starts to show.
  8. #31
    Jun 2002
    Nr Plymouth
    GSXR 600
    I dont! I've finally got my map adjusted and am now running 46psi with a vectra mpi pump.
    Do you still need those part numbers mate? Sorry, I completely forgot about it, again
  9. #32
    Oct 2002
    Luton
    205gti
    Nice one miles.
    Na I'm ok now, I jugged something together to get it in.
    How much did you pay for the MPi pump?? A s I'm going for one this weekend. How do you dig it out the tank?? Or was it just on the shelf??
  10. #33
    Jun 2002
    Nr Plymouth
    GSXR 600
    It was just on the shelf.
    Paid 20 for the first one, but I broke that one (snapped the tail off it) so they let me have the second one for 15
    There is a load of plastic casing you need to take off it. Just make sure the body of the cylinder inside is metal. MPI = metal, spi = plastic.
  11. #34
    Oct 2002
    Luton
    205gti
    So were you festering around in the fuel tank for a bit trying to get it in??
    Is it fairly easy to slot in to the swirl pot in the tank??
    Inspection bit off at the top??
    Cheers for the gen haven't looked at it yet
  12. #35
    Jun 2002
    Nr Plymouth
    GSXR 600
    It goes in and out through the hole under the rear seat.
    I spent a bit of time trying to work out how much it needed shortening by; If you take about 10mm off the outlet tail and use 2 new gaskets (about 3.50 for 2 at vaux) and you might need to use longer bolts, then it fits ok.
  13. #36
    Oct 2002
    Luton
    205gti
    Can you posta pic, I don't get it
    Cheers James
  14. #37
    Oct 2001
    Stoke
    Thread Starter
    now iv got probs with my thottle pot
    usualy gives readings 20ish to ovver 200,
    mine reading 54 to 118
    the dta will only reset to 0 if its under 50.
    this is with it off the engine turned right down or right up :s
  15. #38
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    mm, sounds like a dogy throttle pot or a dodgy connection, not having any luck so far are ya?
  16. #39
    Oct 2001
    Stoke
    Thread Starter
    nope, managed to trick the dta by editing the txt file on my computer then uploading
    but thinking aboiut that its still no good really if its fualty. we shall see
    been around 4 engineering places this morning non of which sell fuel proof seals
    the tps defo has a feed of 5v, and it outputs from 2.5v to 4v on full deflection, im guessing it shud read either 0v or 1v upto 5v :s
    place i got it from say that have a space if i wanna take mine and they will test it, or take my car and thel help etc. so still relying on the seals which jenvy have sent 2nd class AGAIN after i asked for 1st class as they sent the wrong 1s
  17. #40
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    well, you'reright about the tps, i'd take it off and check its range with a screwdriver or similar in it, should be 0. something to 5 volts, sound like its a duff'n to me, so can you connect to the ecu yet?
  18. #41
    Oct 2001
    Stoke
    Thread Starter
    yup that is fixed now, hadto disconect the shielding conection from the earth as it used to be a connection for the lambda oops lol. cant just go swoping wires round :S
    did u get my email about the ats mate your inbox was full
  19. #42
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    no, sorry mate, send me a pm with your address and i'll pop it in the post
  20. #43
    Oct 2001
    Stoke
    Thread Starter
    you inbox still full
    go to your sent items and delete those to make some space!!
  21. #44
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    hmm,strange, i only have one message in there
    will have another look, but send me an e-mail, i'll pick them up later this eve
  22. #45
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    oh, you mean sent items fill the inbox? didnt know that,empty now mate!!!
  23. #46
    Jun 2002
    Nr Plymouth
    GSXR 600
    Cheers James
    Once you have a look at it all will become apparent.
  24. #47
    Oct 2001
    Stoke
    Thread Starter
    engine is now running, however not runing too well....
    my throttle pot not giving out correct values is chucking the thing off a mile, timing+fuel is messed up.
    its driveable though if i take it easy
  25. #48
    Oct 2001
    Stoke
    Thread Starter
    ahh was i suppose to balance them , wondered why they wer ticking over on 2 cylinders lol, sudenly dawned on me when i put my hand over all the trumpets and only 2 wer sucking
    hehe
    running a bit beterm however still need tps. also after a long run when i let go of throttle it tries to die, haveto nurse it for a few seconds then its ok
  26. #49
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    popped that ats in the post mate should be with you soon! glad to hear its running, what map is that you're using?
  27. #50
    Oct 2002
    Luton
    205gti
    Do you balance them by guess work???
    Or do you have one of those flow measuring jobbies???
