Coscast head rebuild
Results 1 to 19 of 19
Thread: Coscast head rebuild
    Jan 2003
    South England
    Linea Rossa Conv Turbo
    I want to build up a coscast head i have, what parts would be best to use, so i can get them all and them a mate will build it up for me? its going to be used in my Astra GTE 16V,
    if anyone can list the parts i will need, as all i have the the head itself, that would be sweet.
    I was thinking about uprated pistons, conrods, and injectors. or is it not worth all the hastle? mind you i wont be putting it together
    cheers
    john
    Nov 2000
    Woking, Surrey
    GTE 16v Turbo
    The pistons and conrods go in the block not the head.
    Uprated injectors are pointless too unless you have a way to map them to the engine.
    Contemplating lots of things
    Astra GTE Turbo - Link Now Working
    Northeast Kent
    so it has no valves, lifters, collets, caps, seats, cams, cam caps ?
  5. Remove Advertisements
    Jan 2003
    South England
    Thread Starter
    Nope its just the head, so ill need to buy everything for it, and i know nuffin, my mate said if i get all the bits i need he will build it for me, but he cant be asked to get them
    cheers
    jonny
  7. #5
    Jan 2003
    South England
    Thread Starter
    is their a kit or sumin i can buy, like you would if you were to rework the head??
  8. #6
    Oct 2001
    Kent
    Beemer
    Hmmmm what would the gen be about not having the cam caps?
  9. #7
    Northeast Kent
    no cam caps is potentially your biggest problem as the are matched during production.
  10. #8
    Jan 2003
    South England
    Thread Starter
    like i said mate i know nuffin really, they may well be their, but it does look pretty bare. i think their are a few spring or sumin init as well??
  11. #9
    Nov 2000
    Woking, Surrey
    GTE 16v Turbo
    Goto Vauxhall and ask them for everything that you need to build your head. Ask for a print out and then you'll have some idea.
    (Its going to be alot of money BTW)
  12. #10
    Jan 2003
    South England
    Thread Starter
    Arrrrrrr money i get that from the tree's i grow ,mate,
  13. #11
    Middlesex
    sideways
    If you don't know whats in the head, how are we meant to know what you need?
    Go away and ask your friend what you need. If he is building it up, he'll know what's missing!!
    Brian Sidebotham.
  14. #12
    Jan 2003
    South England
    Thread Starter
    he lives miles away from me so he cant tell me, ill see if i can snap some pics at the weekend of it, and post them up
  15. #13
    Middlesex
    sideways
    pictures are good.
    or:
    tell us what numbers are missing off the diagram above. The cam caps are the most important, but there is a way of trying to run them in. I forget what it is, but Animal knows. The cam caps are not numbered on that diagram, and are the 11 tops that hold the cams in place. They are fixed to the head casting with studs+nuts..
    Brian Sidebotham.
  16. #14
    Colchester/Brighton
    BMW
    would it not be easier and cheaper to get a warped head and transfer all the necessary parts...?
    [Plug]
    oh i have a spare warped head complete with mint cams if you are interested lol [/Plug]
    The Vauxhall Bug; Once Bitten Forever Smitten
  17. #15
    Gaz
    Gaz is offline
    Sep 2002
    Jhonno, does that mean you have a set of valves?
  18. #16
    Jan 2003
    South England
    Thread Starter
    Well if anyone has a head i can buy and get the parts swapped over, let me know costs,
  19. #17
    Jul 2003
    South Wales
    C20LET Nova GSI
    You'll be able to get a complete engine for the sort of money that you will spend rebuilding the head.
    What are you building the head up for, you said it was to go on your GTE 16v?? Cant you use all the bits from that if the head on yours is cracked or whatever??
  20. #18
    Admin/show reporter Johnny A's Avatar
    Aug 2001
    Oxford
    Nova Estate
    about 1.50 I think, cos thats all ur heads worth without them
    Vauxhall Nova Estate - Isuzu diesel, EPAS and it's an estate yo!
    Vauxhall Carlton V8 - Lexus 4.0 V8, US Cop car paint and light bar
    I used to be a real jerk but now i'm a people guy
  21. #19
    Middlesex
    sideways
    Well, there is a way of running an old set of cams in them with some special lube to try and match the cam caps up. SBD can recommend a method of doing it..
    Brian Sidebotham.
