V-max XE1 kit.
Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 26 to 50 of 99
Thread: V-max XE1 kit.
  1. #26
    Sep 2000
    Falkirk
    A Power Ranger
    XE5 (1199) - (46BHP Increase) This is the maximum this engine can push out with standard AFM and without going to throttle bodies. Giving the camshaft a different lift duration to previous kits, modifying the cylinder head for max airflow and with the insertion of new pistons we have achieved 200PS (196BHP) from this setup. Software is again changed but Fuel pressuer is remained at 3.5 Bar. RPM Level 7500rpm
    WTF!!! now i'm raged
    Northeast Kent
    if someone representing v-max wants to come on here and explain to me how they squeeze enough air and enough fuel through a single plenum and single throttle body to reach 185bhp where 4 bodies and mapable engine management dares to tread, i will happily eat my hat.
  4. #28
    Oct 2001
    Kent
    Beemer
    Yeah!!! Come on V-Max!!!!!!
    lmao
  5. Remove Advertisements
    Northeast Kent
    christ, i missed the XE5 quote. 196bhp, ooookaaaaay.
  7. #30
    Oct 2001
    Kent
    Beemer
    lmao
  8. #31
    Northeast Kent
    how the hell do they stop the AFM spazzing out with flowed head, mad cams and high comp pistons.
  9. #32
    Oct 2001
    Kent
    Beemer
    Exactly!!!!!!!!!!! The AFM would be having fits!!!!!!!!!!!
    This turky **** does my head in chav
  10. #33
    Northeast Kent
    heres something to think about.
    south africant kadett-e superboss, XE + shrick cams + brospeed exhaust + new software = factory quoted output of 170bhp
    i believe the shricks are 268 duration, 10mm lift, which is your textbook fast road cam, basically the best you can have without needing modified pistons and retaining some margin for error needed on mass produced car.
    where do v-max get the extra 15 ?
  11. #34
    Oct 2001
    Kent
    Beemer
    Probably an overreading rolling road
  12. #35
    Nov 2000
    North Ayrshire
    6J Ibiza FR TDi
    And they're happy to have a standard 20XE revving to 7.5K rpm?
    Would standard internals take that?
    VAG history - BLT | CFHD
  13. #36
    Jun 2000
    Swindon
    you'd think after 15 years of claims like this, someone, somewhere, could've substantiated this independently.
    err, that'd be no then - and companies are still taking people for mugs.
  14. #37
    Aug 2001
    Burnley Lancs
    Vectra SRI 140
    Head?
  15. #38
    RDS
    RDS is offline
    Jun 2001
    Plymouth
    Veccy 3.0 24v Diesel
    The only way that V-Max are gonna prove this is to have each setup independently verified at a good rolling road!
    Sir, please step away from the car
  16. #39
    Aug 2001
    Burnley Lancs
    Vectra SRI 140
    I do know that a courtenay chip gave a difference of 8BHP at the wheels over a std ecu map.
    tested on the same rolling road, same day,same car.
  17. #40
    Jan 2002
    Cav Turbo
    Thought that I might try and state a few things:
    The figures quoted have been used and proven.
    Using optimax fuel, increased fuel pressure and different camshafts, these gains are possible.
    you go on to say about an MBE management system... what is this...an ECU...what is the motronic...yep, an ECU
    This chip is NOT! a superchip! Superchips do not have the knowledge to map a motronic ECU as they do not have values for the map and what they change is a bit hit/miss. V-max do have the map so it is every bit as good as the MBE and if not, better...
    Regards
    Gavin
    PS - RPM range is increased to 7500K but it doesn't mean you have to take it there...
    www.wallaceperformance.co.uk
  18. #41
    Scotland
    Saab/Pug/Zaf
    hmm. superchips do have all the cars OE maps and will be adding 10% midrange, 5% top end and -5% motorway cruising as well as adding a degree to the advance WOT for most applications. not ideal as you agree, but what do Vmax do thats so different? and how do they know this?
    any cam over 272 iirc degrees will cause a flatspot in airflow in the AMM area which will errr **** the motronic up basically. its been tried and binned many a time as moving the AMM gave bad throttle response.
    why increase the limit to 7500 to not take it there safely?
    not knocking, just saying. do you sell the cams separately?
  19. #42
    RDS
    RDS is offline
    Jun 2001
    Plymouth
    For once im staying out of this! As i said it will all come out in the next few months as people have this kit Rolling roaded. The XE potentially will be no where near as problematic as the LET is though
  20. #43
    Aug 2002
    north london
    Built COUPE TURBO
    wallace
    well the man spoke! and he knows his stuff.
    t34`d Astra Coupe, brakes by Porsche and Interior by Recaro
  21. #44
    Middlesex
    sideways
    Where? Graphs? would like to see the RR graphs..
    ??? They certainly aren't on the standard induction. (1) The AFM throws a wobbly with anything like better cams. and (2) the AFM also provides a nice air-flow restriction
    Superchip, like everybody else have the addresses and information to decode the maps in the Bosch series of ECUs, for $1000 I could have the program to alter the bosch motronic maps too. So you map to every engine then rather than just programming a pre-worked 'generic' map into each engine? I think not!!
    nice quote, so it's a users risk only thing? Do people have a leg to stand on when the rod exits their block because you've moved their rev limit out of the safe operating area?
    IMO that was a poorly put together post, sorry.
    Brian Sidebotham.
  22. #45
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    got to agree with you brian, dont think you can compare a generic chip to a fully mapped stand alone management system really
  23. #46
    Scotland
    Saab/Pug/Zaf
    well, you could if you compared it to a basemap....some on here know how far out mine was!
  24. #47
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    lmao
    nice, bet its a bit faster than a 'superchip equipped' astra now though eh?
  25. #48
    Scotland
    Saab/Pug/Zaf
    just about
  26. #49
    Middlesex
    sideways
    You know, this got me thinking, why everyone suddenly doubts the N/A gear, yet the phase kits bob along fairly unnoticed.
    The N/A tuners seem to care about fueling and ignition, you want to know what the ignition advance is, you want to see what the injector duration is, etc, etc.
    Yet the turbo peeps are happy with.. yeah, it's running xxpsi of boost, and it's overfueling slightly because the plugs are a bit black.
    In my usual sarcastic way I exaggerate the turbo scenario, but in essence it's true. So long as the next upgrade has a higher boost setting, everyone is happy, the ECU must be fueling correctly, and using the correct ignition advance for your engine, I mean it's all one power kit... strange how trends set in...
    Brian Sidebotham.
  27. #50
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    mm, would be interested in seing some printouts from a couple of thes kits
