Corsa 1.4 16v probs
Results 1 to 2 of 2
Thread: Corsa 1.4 16v probs
    Angry Corsa 1.4 16v probs
    Help please my corsa keeps cutting out when i'm driving usually when hot, misses and picks up slow when accelating and sometimes doesn't start or starts with engine management light on. i've tried resetting the ECU, changing air filter, plugs but nothing has fixed the problem.
    Can ne1 help?
    Oct 2001
    Nova. Sri 1.6 16v TBs
    i had the same problem after i had a bit of a fire problem involving the engine loom on a corsa gsi engine in my nova.
    I rewired it using standard wire from mapllins and it suffers the same problems you refer to. i think its a fualty sensor (burnt out). Probly something to do with the electromnic choke becuase it wasnt to bad until it warmed up!
    If u mange to get the info from the ECU light (counting flashes) then plz let me know. I might need to know to fix mine!
