Severe overfuelling
Results 1 to 16 of 16
Thread: Severe overfuelling
    Admin/show reporter Johnny A's Avatar
    Aug 2001
    Oxford
    Nova Estate
    Severe overfuelling
    My sisters cally (20XE) is overfueling big time. Its basically choking on petrol.
    I have had a good look over the engine, no air leaks anywhere. The ECU light isn't on either.
    It isn't the temp sensor cos I changed it.
    I haven't touched anything on it, it just refused to run properly one morning.
    I am thinking either:
    Duff AMM or
    Duff FPR?
    Any gen on it, anything else I should look for?
    John.
    Vauxhall Nova Estate - Isuzu diesel, EPAS and it's an estate yo!
    Vauxhall Carlton V8 - Lexus 4.0 V8, US Cop car paint and light bar
    I used to be a real jerk but now i'm a people guy
    Northeast Kent
    a garage could check the fuel pressure via that handy shrader valve at the passenger side of the fuel rail.
    one would hope a duff air flow metre would throw up a fault code.
    could you find someone with an XE and swap major engine sensors, trial and error ?
    Nov 2000
    St. Asaph, N. Wales
    Nova, Audi, Landrover
    disconect afm and try it will run but jumpy
    or it's the wiring to the temp sensor
    LEE69
  5. Remove Advertisements
    Aug 2001
    Oxford
    Nova Estate
    Thread Starter
    Disconnected the AMM, didn't wanna start at all.
    Will disconnect the temp sensor and see if it makes a difference at all. Can't see it being that, if it were I would have been a loose connection and I have tried wiggiling the connections.
  7. #5
    Kent
    Haynes Roadster
    Mines overfuelling something cronic too .....
    Please help
    No ECU light. So i haven't got a clue, tested a few sensors, but still nothing
  8. #6
    Oct 2001
    Stoke
    Nova. Sri 1.6 16v TBs
    are you sure the ecu light bulb works?
    might be silly but you never know
  9. #7
    Aug 2001
    Oxford
    Nova Estate
    Thread Starter
    Mine ECU works, it comes on with the ignition, goes out after the engine has started.
  10. #8
    Kent
    Haynes Roadster
    Same here
  11. #9
    Mar 2001
    Torquay
    Audi A3 07 170 DSG
    IF you have lamba sensors,these can go faulty,but not enough to throw up an ecu code/light.
  12. #10
    Aug 2001
    Oxford
    Nova Estate
    Thread Starter
    Doesn't the ECU ignore all lamda readings until the engine is at normal operating temps??
  13. #11
    Mar 2001
    Torquay
    Audi A3 07 170 DSG
    Info here
    Under acceleration or during the warm up period, the system goes into 'open-loop' operation and a richer mixture is allowed to prevent hesitation.
  14. #12
    Aug 2001
    Oxford
    Nova Estate
    Thread Starter
    I have tried to run it twice now, both times the engine idles better when its cold, but goes progressivily worse as it warms up
  15. #13
    Mar 2001
    Torquay
    Audi A3 07 170 DSG
    Try a continuity test on the ecu temp sensor wires.
  16. #14
    Aug 2001
    Oxford
    Nova Estate
    Thread Starter
    going to, need to buy a multimeter first, mine broke
  17. #15
    Aug 2001
    Oxford
    Nova Estate
    Thread Starter
    Do you know the pin numbers for the temp sensor wires?
    Motronic 2.8 ECU
  18. #16
    Mar 2001
    Torquay
    Audi A3 07 170 DSG
    No sorry,but someone will
