How the feck do you fit bonnet lifters?
Results 1 to 15 of 15
Thread: How the feck do you fit bonnet lifters?
    Aug 2001
    Penryn, Cornwall
    BMW 318iS E36
    I bought some ages ago for my old Astra GSi but could never
    figure out where they went. Now I wanna fit them to me Cav but
    I'm still confused, the bonnet just doesn't seem strong enough
    to compress the struts.
    Pics or info would be grrrrrrrrreat (as tony the tiger once said)!
    May 2003
    Lincolnshire
    Audi S4 (B6) 4.2 V8
    Bonnet Lifters
    Those lifters might not be strong enough for the cavey's bonnet.
    I cheated on my astra . I removed one of the bolts to hold the wings on and then i removed one of the other bolts that hold the bonnet hinge to the bonnet and then replaced both with the one's with what you get in the kit .
    This way you don't need to drill any holes that might create rust in the future !!
    Only draw back is the bonnet doesn't open as fully as your standard bonnet prop. Don't get me wrong , it's still opens more than enough to work under the bonnet
    Vauxhall are a shitter for rusting!!
    lee may
    Guest
    Ones off evil
  5. Remove Advertisements
    Mar 2001
    Torquay
    Audi A3 07 170 DSG
    Re: Bonnet Lifters
    Theyll be fine have used same set on a cav and an astra.
  7. #5
    lee may
    Guest
    Unbolt the wing bolt and replace with the supplyed relacement bolt with the nipple on it, do the same again for the bonnet hinge and then just clip the lifter on.
    Job done, Takes about 10 min max
  8. #6
    May 2002
    Rainham, Kent, UK
    Corsa VXR
  9. #7
    May 2003
    Belgium
    '90 opel omega
    can you use the lifters from the trunk?
    Note: the above may or may not be entirely correct.
    I wondered why the frisbee was getting bigger, and then it struck me.
  10. #8
    Aug 2001
    Penryn, Cornwall
    BMW 318iS E36
    Thread Starter
    How do you bolt them though? If you take a bolt out which bolts
    the wing you cant get to the nut underneath cos there is a sheet
    of metal there. Anyone understand that?
  11. #9
    Mar 2001
    Torquay
    Audi A3 07 170 DSG
    The ones that go into the wing have a far corser thread,identical to a bolt you have taken out.
  12. #10
    lee may
    Guest
    s lee said above and the bonnet one's have a captive nut
  13. #11
    Aug 2001
    Penryn, Cornwall
    BMW 318iS E36
    Thread Starter
    Not fecking happy! They dont fit. The bolts fit fine in the bolts that
    you have to remove from the bonnet hinge cos they arent self
    tappered, but the bolts (which are self tappered) you have to
    remove in the wing are fecking self tappered and the new bolts
    arent which means they dont fit. I cant even get a nut to fit
    underneath cos you cant get to that bit as its all sealed with
    metal. Double balls!
    I think the only way now is to tack weld it in.!!!!
    15 minute job my FECKING A R S E!!!!!!!
  14. #12
    May 2003
    Belgium
    '90 opel omega
    would you splease check if they're the same length? cause i still have a spare set of 'em, will obviously need other bolts, but i can make those...
  15. #13
    lee may
    Guest
    DarrynGSi you still on msn?
    I have a spare set of wing bolts you can have if you want
  16. #14
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    the boot lifters are too strong and chunky iirc, bonnet lifters are slimmer so they fit in the seam of the wing with the bonnet shut
  17. #15
    May 2003
    Belgium
    '90 opel omega
    OK, thx m8!
    shame, now i'll have to buy 'em...
    does anyone knows a store where i can get 'em online (and ship to belgium), or does halfords do these too?
