oil preasure on cav
Results 1 to 3 of 3
Thread: oil preasure on cav
    May 2002
    Huddersfield
    Killah XE Cav
    Lightbulb oil preasure on cav
    recently with the weather being nice and warm iv noticed my cavs heating up quicker than normal temp is at 90 and stays there that normal..
    also on idle my oil preasure is just touching red is this normal?? but wen i give it some throttle it goes upto 4 bar..
    car is 1.6spi..
    laf
    laf is offline
    Aug 2001
    Manchester
    Rover 418 SLD
    Temp sounds about right, mine is running a t about 90 unless i'm doing 40mph+ then it drops down.
    Not sure on the oil pressue but it should be low on idle and then pick up as you rev so again sounds right.
    Someone else may be able to give you a 100% answer
    Neil
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    oil pressure will drop as the car heats up, and the oil thins a bit, quite normal, mine starts at 55psi at idle and settles to about 35 when hot, as long as it rise when you rev it'll be fine
