Does a blowing exhaust make car slower?
Results 1 to 14 of 14
Thread: Does a blowing exhaust make car slower?
    Dec 2000
    Gloucester
    3MW B18iS
    There's something not quite right with my engine at the moment. It still feels quite fast but not quite as fast as it was.
    I've noticed that that crappy join between the downpipe and centre section is blowing a bit. I can hear it.
    No, now f*** ***.
    Scotland
    Saab/Pug/Zaf
    Unhappy
    yeah, when i had a hole in the downpipe i lost most of the power and the car struggled to keep above 50mph
    Dec 2000
    Gloucester
    3MW B18iS
    Thread Starter
    Right. It will be sorted tomorrow.
    No, now f*** ***.
  5. Remove Advertisements
    Joy
    Joy is offline
    Sep 2001
    Devon
    2WD CavT / Monaro
    Not only will it make it slower, fuel economy will aslo be affected.
    R Joy
    3.0 V6 Mk3 Cav - Saab B308I, F28, Speedlines, Wilwoods
    Cav 16v Turbo - T34, water inj, 28psi, F28, LSD, Speedlines
    04 Monaro 5.7 CV8 - Pedders Suspension, Wortec Headers & Catback
  7. #5
    Aug 2001
    Nr Bath
    GTE. Rebuilds:Kadett
    Unhappy
    Yea, something to do with a reduction of pressure, My centre section is blowing a bit but its in the join so all it needs is a bit of exhaust paste. That'll be sorted some time this week (i hope).
  8. #6
    Northeast Kent
    you remember at santapod i was under my car with socket set, well i was tightening up a bolt in the same joint you are on about, i did most of my runs with that damn thing rasping and burping as the engine rocked between gear changes. I went to exhaust place but its still not right.
    The thread was stripped, and the thread is the downpipe side, so cant even whinge or blame the notoriously crappy sportex exhaust.
  9. #7
    Sep 2000
    Oxfordshire
    MY03 S3 Quattro
    must be an 8v trait
    my mate had 2 8v gte's a 1.8 and a 2.0
    both either lost, snapped, or had loose bolts on the downpipe joint, causing blowing
    Its suprising who much power you do loose.
  10. #8
    Dec 2000
    Gloucester
    3MW B18iS
    Thread Starter
    I was standing there tonight and it's really obvious now. Want to sort it before my rolling road visit on Saturday.
    No, now f*** ***.
  11. #9
    East Kilbride
    Vauxhall Calibra
    Yeah, exact same problem with my Nova
    Thread stripped at the centre section/downpipe joint causing blowing....Tried everything to sort it, re threading, new bolts, loads of instant gasket, nothing worked..
    Eventually the strian of it blowing was causing the exhaust to flex a little and in thew end the centre section snapped at the back and the backbox fell clean off
    Ended up renewing the centre section and obviously refitting the back box and everything is quiet again
    You really do lose a good bit of power and it does drink a good bit more fuel
    Anything But Ordinary
  12. #10
    Oct 2001
    Kent
    Beemer
    My exhaust has actually snapped at the moment, getting the centre section replaced tonight. I have been driving it though and the performance is definately down and the fuel consumption is horrendous! Filled up my petrol tank on saturday morning and I have only done about 150 miles, the petrol needle is just over half a tank!!
    MattJ
  13. #11
    Scotland
    Saab/Pug/Zaf
    Unhappy whats wrong with that?
    i rarely get more than 100 miles on half a tank
  14. #12
    Oct 2001
    Kent
    Beemer
    That is bad on my car, that equates(?) to 300 miles approx on a full tank. Before the exhaust went pop it could easily do 400+ on a good run.
    MattJ
  15. #13
    Aug 2001
    omega/735SEi/movano
    if the nut is stripped, just drill them out and use normal nuts bolts and washers with the springs, but use a second nut as a locking nut when the joint is tight enough. a leak in the exhaust destroys the scavenging effect flucking up performance
  16. #14
    Dec 2000
    Gloucester
    3MW B18iS
    Thread Starter
    No threads have been stripped.
    I thought it was the squashy seal thing. So I went round the motor factors to buy one. I was in the process of shininh my torch down onto the joint when I noticed a shiny patch on the exhaust pipe.
    It looks like the joint just downstream of the flex coupling is loose. So I bought some new exhaust clamps.
    About to go out and fix it. The car sounds like a tractor at the moment and is definitely slower.
    No, now f*** ***.
