Results 1 to 7 of 7
Thread: LET Backpressure in exhaust
    Jun 2001
    Sweden
    Opel Calibra T -93
    Did some measurements on backpressures at diff boost with original exh.manifold. Measured just before the entrance to the Turbine at 4000 rpm.
    Useful information or "nice to have" ? I dont know, but here it is.
    Boost / Backpressure.
    - 0,2 / 0,25
    0,0 / 0,45
    0,1 / 0,55
    0,3 / 0,75
    0,5 / 0,90
    0,7 / 1,30
    0,9 / 1,80
    1,1 / 2,00
    1,3 / 2,20
    1,5 / 2,45
    Nov 2000
    Woking, Surrey
    GTE 16v Turbo
    Whats the backpressure measured in? Pa?
    Contemplating lots of things
    Astra GTE Turbo - Link Now Working
    Jun 2001
    Sweden
    Opel Calibra T -93
    Hi Cemesis, both boost and backpressure measured in Bar !
    Oct 2001
    Kent
    the car in front
    Do you have any more, or any rpm figures?
    You see, 1 bar boost at 3Krpm is not the same as 1 bar at 5Krpm, the backpressure will be much higher the second time
    I'd like to use these figures in my website, if you don't mind
    PS:
    you have specified that you don't want to receive emails or Private Messages from this board. Is this intentional, or some default setting you never changed?
    Jun 2001
    Sweden
    Opel Calibra T -93
    Hi JohnA,
    All the measurments is done at 4000 rpm.
    Mybe I can do some tests at higher revs.
    I will also do some tests after the Turbine.
    If you want to use the figures on your exellent site, please do.
    Private mess. is now ON.
    Oct 2001
    Kent
    the car in front
    Originally posted by c20let
    ...If you want to use the figures on your exellent site, please do...
    One does what one can, doesn't one?
    Apr 2002
    Brazil, São Paulo
    Astra GTE 2.0 8V Tur
    high back pressure = low power. Because this need use a big turbine and good exhaust manifold when you think in make a really strong turbo engine.
    cheers,
