Fault code on cally t
Results 1 to 8 of 8
Thread: Fault code on cally t
    JMC
    JMC is offline
    worcester
    Vectra & Astra VXR's
    Question Fault code on cally t
    Just had fault code 113 (boost control out of range) come up on my calibra turbo, it's a 94 L plate, any one know what it is?
    cheers
    Jason
    May 2002
    Ammanford, S. Wales
    Monterey 3.1 Diamond
    youve hit your boost limit, wind back the actuator a little to prevent the wastegate opening for so long.
    Oct 2001
    Kent
    the car in front
    Take a look at my website if you want more info.
    Particularly the 'motronic' stuff in the 'recources' page
    JMC
    JMC is offline
    worcester
    I have set it too 6psi and still the same
    May 2002
    Ammanford, S. Wales
    turn the key to lights on the dash and back to off 30 times to clear the code.
    How worn is ur acutator spring, when was the actuator last changed/checked?
    May 2002
    Mansfield
    Calibra Turbo
    Do you have a boost gauge then?
    Whats the overboost?
    JMC
    JMC is offline
    worcester
    The overboost comes in at 11psi so its set at 10psi most of the time, so i set it too 6 psi and still the same
    May 2002
    Rainham, Kent, UK
    FWD LSD C20LET Calibra
    that won't work, the c20let uses a BOSCH Motronic ECU, so just disconnecting the power works. You can do the 30 on/off trick with Simtec ECUs (ie Ecotec engine).
    www.topbuzz.co.uk : FWD LSD C20LET Calibra
