Nova XE radiator
Results 1 to 5 of 5
Thread: Nova XE radiator
    Apr 2002
    County Durham
    a car
    Nova XE radiator
    I'm worried about the 1.2 radiator I'm supposed to be using for this xe conversion.
    Are we sure that it will sufice for cooling?
    What other options have peps went for?
    thanks,
    steven
    Content.
    Jul 2000
    Manchester
    Vectra/Sunbeam/Nova
    which 1.2 rad if its the one without the legs it will be fine if it has legs arround 5cm on the bottom get a gsi one
    Apr 2002
    County Durham
    a car
    I'm not worried about fitting it in there, just its thermal properties.
    Content.
    Jul 2000
    Manchester
    Vectra/Sunbeam/Nova
    The one with the legs are smaller therefore less cooling
    the early 1.2 and the gsi are bigger (same rad) so use one of those if you have the later smaller one on legs you will also need a new fan and shroud as well
    Awaiting Email Confirmation
    Nov 2000
    St. Asaph, N. Wales
    Nova, Passat
    i ran mine on a 1.2i stilted rad and it was ok
    ran it on a pattern gsi rad and it ran hot
    i would recomend a.....
    brand new valeo gsi spec rad....
