Switching fuel pump relay to imobilise car?
Results 1 to 6 of 6
Thread: Switching fuel pump relay to imobilise car?
    Apr 2003
    Kent UK
    Drives 20xe'd Astra
    I want to do a quick and dirty imobilise of my car using the feed to the fuel pump to stop the engine from being started.
    Will the ecu detect the relay as a fault and bring up a fault on the dash?
    Any other quick and easy ways using just a relay that has to be energised vai a hidden switch to imobilise? I want to also have the normal red flashing LED on 1 pole of the relay when the car is imobilised too.
    I intend to use a timer relay so its self setting after say 20 secs of ign off, manual switch reset to enable car starting.
    Cheers.
    MikeT.
    wanted:GSI Astra fanstyle wheel center cap.
    Drives: C20xe'd Astra 3 CD
    Feb 2003
    Tring, Herts
    C20XE coscast 'max van.
    dont see why not... noone would be able to work out what the ecu light was even if it came on - and even then - what are they gonna do about it?
    hidden switch seems easy enough.
    Running a 30 quid carlton taxi to Italy and back for a laugh... and charity..
    lee may
    Guest
    Find the fuel pump fuse in the fuse box and put a switch inline with one of the wires so that when the switch is on it would be like having no fuse in it. The car will start with the fuel thats in the lines but after about 10 seconds it will just die and be out of fuel.
    When ever I go on holiday I allways remove things like that just incase
    Northeast Kent
    the ecu doesnt see the relay at all, in the sense of fault detection anywya. so it wont upset it.
    the relay also feeds the injectors, so you could in effect totally immobilise ANY fuel activity.
    Feb 2003
    Glasgow
    various
    On the renaults renault fitted a switch to immobilise either the igntion (the more usual) or the fuel pump. Depends on the mood othe fitters I think.
    Theres a daft wee toggle switch that does the job. Not the best set up either, a switch with a couple of crappy wires crimped in and if your very lucky they may be soldered on, rare though.
    So aye thats fine.
    Chris
    I don't give a p-h-u-k whatcha gotta say!
    Apr 2003
    Kent UK
    Drives 20xe'd Astra
    Thanks guys, I have some surface mount very thin switches here so I can mount one under some trim or carpet somewhere to trigger the electronic timer relay reset. That should work a treat, turn ign off and even if you leave the keys in the ign, within say 20secs the timer times out, red LED starts to flash, fuel relay is inhibited and the only way to restart will be with ign on and press the trim switch point.
    Job almost done
    MikeT.
