Are early XE rods forged?
Results 1 to 7 of 7
Thread: Are early XE rods forged?
    Aug 2001
    Swindon, Wiltshire
    Astra 3/Corsa C/Cav
    as above
    PhilAstra@Hotmail.com
    Northeast Kent
    no
    Jun 2002
    Wrectum
    Shuvit, e36 track car
    concise
    Aug 2001
    Swindon, Wiltshire
    Astra 3/Corsa C/Cav
    interesting....
    Originally posted by 0ddball
    no
    the early engines also hold a whole host of motorsport derived goodies, heres a little list off the top of my head
    coscast head (dense pressure cast alloy)
    13mm valve guides (nice thick walls, GM heads 11mm)
    bigger valve seats (handy if you want oversized valves in future or recut the seat)
    forged pistons (late engines were cast)
    forged con rods
    light weight crank (late ones couple more KG)
    lighter 7.2kg flywheel
    wider high grade big end and main bearings
    nitrided cams
    sodium filled exhaust valves
    shorter ratio first gear
    remember saying this? XE questions... have now revisited scrappy
    Northeast Kent
    yup why ?
    Jun 2002
    Wrectum
    how early is early? will my 89 cav have these aforementioned goodies?
    May 2002
    Ammanford, S. Wales
    Monterey 3.1 Diamond
    they brought out the mk2 astra gte 16v back in 1987 which an E plate i think.
