How i can desconnect the gearbox linkage?
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 27
Thread: How i can desconnect the gearbox linkage?
    Apr 2002
    Brazil, São Paulo
    Astra GTE 2.0 8V Tur
    Scotland
    Saab/Pug/Zaf
    undo the 13mm pinch bolt where the linkage comes out (or under probably in your case) the bulkhead.
    Apr 2002
    Brazil, São Paulo
    Thread Starter
  5. Remove Advertisements
    Scotland
    Saab/Pug/Zaf
    yeah, is this what you wanna undo?
  7. #5
    Apr 2002
    Brazil, São Paulo
    Thread Starter
    yeap!!!
    but where in gearbox stay this bolt???
  8. #6
    Scotland
    Saab/Pug/Zaf
    the box just has a rod which slides into this bit - the 13mm bolt pinches the two together
  9. #7
    Northeast Kent
    theres an easier way than that. theres a circlip on the end of the pin that goes through this universal joint. prise of the circlip, extract the pin and then it seperates.
  10. #8
    Apr 2002
    Brazil, São Paulo
    Thread Starter
  11. #9
    Scotland
    Saab/Pug/Zaf
    the pin odders is talking about is thro the white block, but the selection turret which is what i imagine you mean
    tho on the 8v linkage this doesnt give you a lot of room to get the engine&box out the top - i always just undid the 13mm tho, so cant say it wont work
  12. #10
    Apr 2002
    Brazil, São Paulo
    Thread Starter
  13. #11
    Northeast Kent
    i dont know a simpler way to describe it than with a picture, which ive already done.
  14. #12
    Apr 2002
    Brazil, São Paulo
    Thread Starter
  15. #13
    Feb 2002
    Fareham, Hants.
    C20XE 13S Z20LER Z17DTH
    I think there's confusion here, Matheus is talking about removing the gear selector cap and pulling off the sump!
    Matheus, you don't need to 'open' the gear box to disconnect it from the gear lever! Look just foreward of the bulkhead, or follow the linkage back until you see the either the 13mm pinch bolt of the little pin with the spring clip.
    They're there, in their room.
  16. #14
    Apr 2002
    Brazil, São Paulo
    Thread Starter
  17. #15
    Apr 2002
    Brazil, São Paulo
    Thread Starter
  18. #16
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    follow the route of the bar that leaves the bottom of the gear lever towards the gearbox, on the end of the bar is a bolt that clamps the bar to the linkage, undo this and withdraw the bar from the linkage, to take the linkage from the box you have to take out the pin that the linkage pivots on and then the linkage comes off
  19. #17
    Feb 2002
    Fareham, Hants.
    Maybe a better way to find it would be to get under the car and find the rubber boot covering the bottom of the lever, then follow this towards the engine and undo the first bolt you come to on the linkage.
  20. #18
    Apr 2002
    Brazil, São Paulo
    Thread Starter
    hum..i don´t know what bar you mean...
  21. #19
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    underneath your gearlever there is a bar that transfers the movement of the gearlever forwards toward the engine bay
  22. #20
    Northeast Kent
    here is pinch bolt. pinch means clamp, or hold together, compress
  23. #21
    Apr 2002
    Brazil, São Paulo
    Thread Starter
  24. #22
    Apr 2002
    Brazil, São Paulo
    Thread Starter
    thank you Odd.. .
  25. #23
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    not in the engine bay at all, if you are only trying to remove the gear linkage ontop of the gearbox itself then you must remove the pin that goes into the pivot ontop of the gearbox next to the mount, on oddballs picture above it is directly below the starter motor, but toremove the whole thing you may have to remove the attachement to the gaerlever
  26. #24
    Northeast Kent
    ok, well the clamp bolt will only be in one of 2 places.
    it will be here
    or it will be here
  27. #25
    Apr 2002
    Brazil, São Paulo
    Thread Starter
    humm, thank you Region, i will try find that. Really thanks for help friends.
