Damn fan belt is p*ssing me off, somebody stop the squeeking!
Results 1 to 21 of 21
Thread: Damn fan belt is p*ssing me off, somebody stop the squeeking!
    Mar 2002
    North West London
    Astra GTE 16v
    Angry Damn fan belt is p*ssing me off, somebody stop the squeeking!
    Right, when i first got the car, i noticed the faint squeeking of the fan belt when the car was just cruising along (ie. foot off accelerator, boot off brake, for instance if ur on the motorway and going downhill).
    So i thought, might aswell change the belt, so went to halfords, got the right one and went about fitting it.
    Fitted it (knowing full well it would stretch and may need adjusting again).
    Ran car about, and it started squeeking again
    Anyways, had a go and tightening the adjuster even more today, which i think i have managed to do.
    But it now screetches even more ?? And now more randomly, like accelerating, braking etc. Just randomly.
    It has been said that Halfords fan belts are poop, althought i thought a belt was a belt?
    Could it be halfords fan belts are crap?
    How far up the adjuster should the nut/bolt be? There isnt a lot of play in the belt.
    Any ideas, as its doing my nut in.
    « GTE 16v »
    Oct 2002
    North London
    Astra TD/Astra Sport
    go to a motorfactors and ask for a slightly shorter one thats wat i did
    Owns a white Mk3 turbo diesel with more stopping power then engine power..... boosting 0.9bar, Now De-catted!!
    Jan 2002
    Stoke-on-Trent .. 0-60 5.15 Proven
    Nova LET 13.581/12.580
    wd 40
    Mark Beeson
    If its a NOVA I might know. Ive tried/fixed everything.
    Nova 280+ bhp and a quaife straight cut gearkit + ATB and water injection and 6 pot calipers that wont fit! Now I have a power steering setup for my nova!
    I also own a Citroen Xsara VTS
    MIGWeb Moderator
    Midlands
    Nowt
    WD40 ? You are taking the piss ?
    Are you sure you have the right belt ?
    If so, try getting some belt dressing and try that, Halfords do it I belive, comes in a spray can thing. Should do the trick.
    Are you sure its the belt making the noise and not the alternator by the way?
    Paul
    Mar 2002
    North West London
    Astra GTE 16v
    Paul
    Would an alternator make that horrible squeel usually associated with a fan belt?
    Its really annoying, as just when i think its sorted, it starts again, and gets worse than before
    would a non-halfords belt help out? I had a continental on there before, is there any difference?
    I noticed there was more teeth on the halfords one compared to the continental i took off.
    « GTE 16v »
    Apr 2003
    Kent UK
    Drives 20xe'd Astra
    If you think its the belt that is squeeking and its at idle so you can do it while the car is stopped with the bonnet up, spraying wd40 or quacker (duck) oil on the belt will instantly though temorarily silence it. If its a bad bearing in the alternator then it will still squeek.
    I think thats what the prev poster meant by WD40, just a method of identing the problem.
    wanted:GSI Astra fanstyle wheel center cap.
    Drives: C20xe'd Astra 3 CD
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    My Mk2 Astra did this random screeching thing when I first bought it, I tried a new belt and eventually new alternator. After nearly a year I found it was the front flexi join on the exhaust where it bolts to the floor of the car. It's a metal washer type thing covered in rubber, so when the rubber wears away the metal rubs on the metal of the exhaust and makes the horrid noise.
    Check that.
    They're there, in their room.
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    are the bushes in the adjuster arm mount ok? these wear out and give a little movement causing belt slip
    Mar 2002
    North West London
    Astra GTE 16v
    Check that.
    So the joint that you can see through the engine bay?
    Ill check this tommoz. Cheers.
    Can an actual alternator cause this sound?
    « GTE 16v »
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    maybe the bearing but this usually sounds like a turbo spinning up not a belt slipping, unless its really fecked
    Mar 2002
    North West London
    Astra GTE 16v
    hmmmmmmmm never thought of that either.
    Ill have a check tommoz. That sounds like a good explanation.
    Could it also be the actual alternator bushes are worn, causing it to wobble, and the belt to slip?
    « GTE 16v »
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    the alternator runs ona bearing, if this wears you generally hear it run up, like a quiet turbo whistle, sounds like the bushes to me,the alternator moves and pulls the pulleys out of alignment and the belt slips
    Aug 2002
    Near Gt Yarmouth
    Astra Estate
    Or when the belts off bit of rough rubbing paper and take the shine off the pulleys,works a treat when all else fails
    Need custom t-shirts?...www.deathgimp.co.uk
    Mar 2002
    Norwich
    Corsa 1.2 & 08 YamR6
    Had this on my cav last year and i agree with BigKingy it drives ya f*ckin mental!! especially in the wet weather I replaced the insulating bushes from vaux (£10 for 3 pieces of rubber ) and tightened the belt adjuster and this cured it. Very occasionally it will do it when its REALLY wet but spose that cant be helped
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    Hence why V belts gave way to ribbed serpentine belts I suppose.
    Mar 2002
    North West London
    Astra GTE 16v
    So you replaced the alternator bushes? And then tightened up the adjuster?
    Ive tried busting a gut pushing up the adjuster, but theres still about 1cm of adjuster left, i just cant push it any higher.
    Any good suggestions for using sommit to leaver it further?
    Tried a few wrenches but to no avail
    « GTE 16v »
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    dont do it too tight, you'll shag the alternator bearing, i use a jack handle between the block and alternator, do it up till u have aropund 10-15mm flex in the belt
    Jan 2002
    Sorry I spoke
    Mark Beeson
    Mar 2002
    North West London
    Astra GTE 16v
    Right, me and me old man had another go this morning at tightening the bastid.
    Im now convienced that it is at the correct tightness.
    After feeling the movement on the fan belts in davcohen and damn lagrues cars the other day, im sure mine is at correct tension.
    After given it a little test drive, it all seemed sorted
    Until i went on a long drive to pick the missus up.
    Once again the squeeking returned, but to a lesser extent.
    It now seems it squeeks when after motorway journeys.
    Does this make any sense?
    Im starting to get the impression it might not be the belt any more (although it was causing problems) so shall take a look at the bushes and exhaust joint mentioned above.
    Could it be the alternator? Im thinking this could cost a lot (student thinking) if it was?
    « GTE 16v »
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    Adam me old mucka, a complete alternator from a scrapies only gonna be a tenner! I'm sure someone round your area can sort you one! You could, if you're feeling adventurous, get some bearings and rebuild the bugger yourself.
    Probably best to go the scrappy, eh?
    Oct 2002
    North London
    so thats what u were doin while my back was turned why u sly dog!!
