Petrol gauge on digidash gone loopy!
Results 1 to 2 of 2
Thread: Petrol gauge on digidash gone loopy!
    its reading no 'blips' and flashing at me!
    but i put some in a day or two ago, not sure how much i put in... done 68 miles since fill up, always put more than a tenner...
    Got a feeling just a wire has come loose at the back of the dash - or could it be more complicated than that?
    Dom is offline
    MIGWeb Moderator Dom's Avatar
    Sep 2001
    73bhp MK4 Astra POS
    No blips and flashing is an open circuit or fecked tank sender
    Disconnect the wire going to the tank sender and ground it - if the gauge rises then its your tank sender at fault, if the gauge stays the same, its a break in the cable between the tank and the dash
