phase 3.5 fulling
Results 1 to 5 of 5
Thread: phase 3.5 fulling
    Apr 2002
    norfolk
    LC, Astra GSi Turbo
    phase 3.5 fulling
    when my cav last ran on the rollers it was underfuling at the top end what is the best combination of fuel pump,pressure reg and injectors so it doesnt run lean at the top
    andy
    May 2002
    Mansfield
    Calibra Turbo
    Ideally get a set of red injectors, You can keep your original fpr (3bar) and fuel pump if not the fpr should be 4.5 bar which should have come with the phase kit and a bosch 909 fuel pump.
    May 2002
    Mansfield
    Calibra Turbo
    Also invest in an air/fuel ratio gauge that takes a "live" lamda reading, Ive just got one cos I suspect my car leans out at high revs, only 52 inc
  5. Remove Advertisements
    Mar 2002
    was it a drop in fuel pressure causing the underfueliing if so what was the fuel pressure and at what revs did it drop
  7. #5
    Sep 2000
    Near Stirling
    10s Evo VI,12s Astra
    Assuming you have fitted all the phase 3.5 bits, just make sure your injectors are clean and performing well, and ensure you have a high enough voltage going to the fuel pump.
