put a 2.0 16v in nova and having real trouble setting up gear linkage. i am using nova linkage on f16 box with the white block turned round, i cant get fith and the rest of the gears are seriously crap, using normal method of setting gears ie. drill bit in hole im left with 1st where reverse should be it is having trouble reaching either way,ie. 5th and reverse. have only got reverse through bodging and all gears are hard to engage, any nova16v gear help appreciated!!!!!!
