Grrrr, need to strengthen that rear engine mount
Results 1 to 17 of 17
Thread: Grrrr, need to strengthen that rear engine mount
    Nov 2000
    Woking, Surrey
    GTE 16v Turbo
    Unhappy Grrrr, need to strengthen that rear engine mount
    Even after some correct alignment of the gear linkage I still get the problem that a quick change to 3rd from 2nd makes a CRUNCH!
    So, I've had suggestions of putting a bolt through the rubber mount and inserting pieces of rubber into the gaps on the mount but it was all discussed a while ago and I can't really remember.
    Anyone got any hints as I need to get it all running well before the 26th
    Contemplating lots of things
    Astra GTE Turbo - Link Now Working
    Middlesex
    sideways
    You can chop up bits of rubber and stuff them in the air gaps of the engine rubber mount, and then gloop it all with black silicone sealant. That will make it stronger.
    Failing that, just get a TAS rear mount, I presume it's that one that your'e on about?
    Brian Sidebotham.
    Nov 2000
    Woking, Surrey
    GTE 16v Turbo
    Thread Starter
    Yep, rear mount that takes all the strain when the engine leans back on full load. How much for a TAS one and I assume its just the rubber part not the whole thing.
    Also, didn't I hear that someone bought some TAS mounts and they didn't fit properley? Or am I thinking of something else?
  5. Remove Advertisements
    Middlesex
    sideways
    Nope, you remember right, Rob (16vastra) eventually got a set after canceling his order, and couldn't get them to fit well....
    The TAS mount is the rubber bit, and metal plate that bolts onto the chassis. I doubt they could have got that one wrong to be honest! lol
    Brian Sidebotham.
  7. #5
    Jan 2002
    West Sussex
    Astra 1.9CDTi 8v
    Bearing in mind this engine has a mega torque value, surely there is a poly mount or something which will take the strain?
    I think Mr Heley might have TAS engine mounts on his 'green' Astra- I think he mentioned it before.
  8. #6
    Middlesex
    sideways
    Thats all thats different about that mount, the TAS one has a solid hard rubber insert rather than the vauxhall aireated soft rubber mount
    Brian Sidebotham.
  9. #7
    Nov 2000
    Woking, Surrey
    GTE 16v Turbo
    Thread Starter
    Cool, might as well do it properley.
    Where can I get a TAS rear mount from? Direct from TAS?
  10. #8
    Middlesex
    sideways
    yep, they sell direct.
    http://www.tas.uk.com
    Brian Sidebotham.
  11. #9
    Administrator
    Jun 2000
    Hampshire, UK
    Family Car
    what about a mk3 200ts rear mount?
    will this not fit?
  12. #10
    Scotland
    Saab/Pug/Zaf
    with fitting the rear mount, support the box & engine and take off the rear claw bracket (oh, this is f20, i dont know the rear setup of the 28 but i assume its similar/same)
    fit this claw and mount to the chassis FIRST cos there aint no way its gonna bolt up otherwise and then adjust the gearbox support to mate the box to the claw and do it all up tight.
    its fiddly, but not the hardest of the TAS mounts to fit
  13. #11
    Northeast Kent
    trouble with stiffening the rear mount is that all the strain will be transfered through the chassis instead.
    I bought a new rear mount, then chopped up large chunks of an old passenger side mount, RTV'd them in all the gaps.
    I knew i'd done a good job because i could feel engine vibrations through the car afterwards.
  14. #12
    Middlesex
    sideways
    The chassis should be able to deal with that. It's better than the gearbox moving, and then transfering it's load to the chassis if you get what I mean...
    Will make the car vibrate more...
    Brian Sidebotham.
  15. #13
    Scotland
    Saab/Pug/Zaf
    naaa....i've only chipped the 1 tooth
  16. #14
    Middlesex
    sideways
    lol!
    I fancy making up some rose jointed all-ali engine mounts, no rubber... I think they would be beneficial.. Just need to get some designs done..
    Brian Sidebotham.
  17. #15
    May 2002
    Basildon, Essex
    Mk3 Astra (again)
    I've been thinking about knocking up some rose jointed stabiliser bars at work for a while now...
    it's just trying to work out where to bolt to that i get confused
    VXR Vectra
  18. #16
    Sep 2000
    West Country
    Harry Hockley Motorsport sell uprated engine mounts for the Astra.
    Give them a call on 01686 628594
    As you get older the toys just get more expensive.
  19. #17
    Scotland
    Saab/Pug/Zaf
    @ 250 quid or summat daft
    i may be able to get a discount for stuff there tho, havent tried yet (cant afford a sodding thing they sell lmao)
