ET37's On a Cav GSI 4x4
387 views 7 replies 3 participants last post by  Vince
#1 ·
I realise they are well below the et49 but what inplications would this have??
Any advice appreceated as I've offered some and need to know whether its a good idea or not.
#7 ·
not really as the higher ofset will make the wheels stick out more causing the wheels to camber more so they will be putting more strain on the box causing it to overheat and spit out its dummy, or pas fluid out the breather.
On a 4x4 i wouldnt go over a 45mm ofset, just to be safe, mine was a 4x4 till it went boom due to uneven tyre wear and i changed mine round every 3k miles too
