Driveshaft
Results 1 to 10 of 10
Thread: Driveshaft
    Sep 2000
    Manchester
    Cav SRi Turbo
    Driveshaft
    Last week I changed the driveshafts on my astra GSi for reconditioned ones.
    I also fitted a new driveshatf balancer, The haynes stated it should be 268 - 270mm away from the inner CV joint. So I fitted it at 270mm.
    Upon removing the old shaft I noticed the balancer was 280mm from the inner joint.
    Now my problem starts. i changed both front tyres at the same time.
    Before fitting the tyres and shafts the steering was spot on, Now I have wheel wobble at around 80 mph.
    Obviously I will have the wheel balance checked,
    But what should the balancer be set at????
    Apr 2001
    NW England
    Astra Belmont CDi C20LET
    Set it the same as the old shaft was.
    Mart.
    Time waits for no Man and very few Women
    Gagged v5uk's Avatar
    Oct 2001
    Wigan Lancashire
    LET Corsa Pickup
    erm
    Terry the speed limit's only 70mph it this country
    Yeh I’d say try setting it as the old one was and see if that helps maters
    “Carrera” a word to make women think the socks you have shoved down your pants is actually your C**K
  5. Remove Advertisements
    Northeast Kent
    that weight is similar diametre to the cv joints. Could just as easily be the cv's putting things off balance.
  7. #5
    Apr 2001
    West Yorkshire
    Zafira Tourer CDTI
    Terry, Are you using the wrong Driveshaft mate?,
    If your car is still the Astra GSi then you should fit the GSi Shaft, the normal shaft (with balancer) will fit your car but you really need the Shaft that is in two sections and mounts onto the rear of your engine.
    Just guessing but I think thats right.
    Bren, 13.563@108.64MPH York 31st May 2004
    Uncareful Owner of a 13 second car.www.astraturbo.co.uk
    Click here to see Fastra whup Scooby Ass up the Qtr
  8. #6
    Sep 2000
    Manchester
    Cav SRi Turbo
    Thread Starter
    Both the driveshafts are from Vauxhall, Fully reconditioned. The balance is even new from Vaux, So all should be correct
    Bren, I might sound stupid now but what do you mean?
    These shafts are what is listed for my car, and exactly the same as what came off the car. What is this shaft which come in 2???
  9. #7
    Apr 2001
    West Yorkshire
    Zafira Tourer CDTI
    I use the thicker shafts with the alloy mout similar to your engine mount that bolts onto the engine,
    I have taken a picture of the spare one that I have just bought for mine but I can't find the uploader thing on Mig, Gonna keep looking so i'll post it up when I find it.
  10. #8
    Apr 2001
    West Yorkshire
    Zafira Tourer CDTI
  11. #9
    Sep 2000
    Manchester
    Cav SRi Turbo
    Thread Starter
    I've never seen on elike that before
    Whats the difference? Strength?
  12. #10
    Apr 2001
    West Yorkshire
    Zafira Tourer CDTI
    Not sure if its for strength or smoothness.
    But 90% sure they were original equipment on the Astra Gsi.
