Chips (but no fish!)
405 views 5 replies 4 participants last post by  V6 Pete
#1 ·
What are the differences between Superchips and Unichips or are they very similar in what they achieve.
I would like to know peoples experiences of either or any other type of performance chip.
Do they work, what differences did they make, how much, where from and are they worth it??
#2 ·
Super Chips - fixed map chip, in theory no better than your current one.
Uni Chips - mapable to your engine spec and mods, should see a gain over your current chip, if its well set up.
#5 ·
does anyone have the unichip on their mota? What engine is it going onto?
Need to bear in mind that you are still only modifying your standar ecu and for the cash after buying/fitting/setting up you will probably c better results with a full replacement mappable jobbie!
Stan
#6 ·
Stan
I am having issues with reading the Vauxhall ECU, so if I did chip I would be looking for something which can replace the vauxhall chip all together, with something garages can access the details for. So is a Unichip suitable for this? 2.5 24v block.
