Why lighten the flywheel?
Results 1 to 22 of 22
Thread: Why lighten the flywheel?
    MIGWeb Moderator Paul's Avatar
    Midlands
    Most days
    Any gen on the above ?
    Why do people have there's machined?
    Does it help the engine to rev better ?
    My engine is a 1.6 8v, any point in doing anything with the flywheel ?
    The engine is sitting in my shed floor at the moment, so its no extra trouble!
    Cheers,
    Paul
    Dec 2000
    Gloucester
    3MW B18iS
    Engine revs up/down more quickly.
    Acceleration of car in 1st gear a few percent better, in 2nd a bit better, by 3rd gear no significant difference.
    No, now f*** ***.
    Midlands
    Most days
    Thread Starter
    Cheers Tom.
    You had yours done ?
    How much should I pay ?
    Hope your engine is coming on well, hope to see it at a MIG event this year.
    Paul
  5. Remove Advertisements
    Dec 2001
    Chelmsford, Essex,
    Astra1.8, Zaf1.8/1.9CDTI
    Re: Why lighten the flywheel?
    Cheers,
    Paul
    Makes fast gearchanges smoother, but makes sedate gearchanges lumpy, unless you balance the throttle.
  7. #5
    Nov 2000
    Reading Berkshire
    Vectra GSi & GTE 16V
    Cheers Tom.
    Paul
    Had this done on my Cav GSI, made a HUGE difference to the way the car performed.
    It felt revvier and pulled alot easier because of it.
    65 exchange from our friends at SBD
  8. #6
    Sep 2001
    rainford
    astra mk4 sport
    if u get a lightened one fitted there is 1 bad point apart from the above is that the engine me idle rough due to the less momentum keeping the engine running
    am i right ne one???
  9. #7
    Dec 2000
    Gloucester
    3MW B18iS
    Depends how much you lighten it. Mine idles fine.
    No, now f*** ***.
  10. #8
    RDS
    RDS is offline
    Jun 2001
    Plymouth
    Veccy 3.0 24v Diesel
    Nope cos mines got a 4kg one and it idles just fine
    Sir, please step away from the car
  11. #9
    May 2002
    liverpool
    Zafira VXR STAGE 2
    ive fitted a 2.0xe one to my c25xe .... not started it yet but hope it idles ok what u recon the benefits. disadvantages of it will be?
    Im a Daddy Wahoooo
  12. #10
    Noz
    Noz is offline
    Jun 2000
    Wolverhampton
    Vectra SRi V6
    There's huge benefits for the V6's, as their flywheels are absolutely monstrous. Because the markets Vauxhall sell in require some cars to tickover really really low, a big flywheel was put in as standard. Here in good old Blighty, the tickover doesn't have to as low, so the flywheel can be stripped to nearly nothing.
  13. #11
    Aug 2001
    do u lose some top end by lightening the flywheel?
    roshan_j81@hotmail.com - Life moves pretty fast. If you don't stop and look around once in a while; you could miss it............
  14. #12
    Oct 2000
    Bracknell
    Mondeo, MR2, Manta
    you don't gain or lose any power.
    Originally Posted by Brian_S: Woooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo!
  15. #13
    May 2002
    liverpool
    Zafira VXR STAGE 2
    Right im off to try make an exhaust for the conversion gearbox fly and engine are in... let you know how i get on, if ne1's interested that is?
    Im a Daddy Wahoooo
  16. #14
    Dec 2001
    Chelmsford, Essex,
    one drawback of going really light is, the engine becomes very easy to stall.
    My belmont SXi used to conk out if you got to full lock!!
    Wife used to stall it a lot just reversing into the drive
  17. #15
    May 2002
    Rainham, Kent, UK
    Corsa VXR
    it used to be last year, but this year, new engineering shop contact, now 188!
    Got mine down by Power Zone for 70 (9kg down to 7kg).
  18. #16
    Jan 2002
    Lincolnshire
    too light a flywheel will cause rough idling.
    The reason is when a cylinder is on the firing stroke, a proportion the energy released from the combustion process is stored in the flywheel as rotational kinetic energy.(speed up)
    As a cylinder hits compression, energy is required to "do work" on the mixture in the cylinder, i.e. compress it. The stored energy is called on and hence the flywheel will lose rotational kinetic energy.(slow down)
    the energy transferred is called the "fluctuation of energy". If a flywheel becomes lighter, it stores less energy, so it's about finding the point where light becomes too light
    cheers
  19. #17
    Mar 2001
    London
    Audi S4 Biturbo
    Modern engine management (Motronic onwards) have very good idle and anti stall programs. And a bigger engine will naturally have more inertia (bigger heavyer crank etc). Proberbly why RDS and others notice no difference in idling.
    On a cammed up smaller engine with carbs or something you would notice the difference proberbly. A rasie in idle speed will sort that though.
  20. #18
    Dec 2000
    Gloucester
    3MW B18iS
    Don't pay 180 at SBD. Get your local engine rebuilders to do it for around 50.
    No, now f*** ***.
  21. #19
    Midlands
    Most days
    Thread Starter
    How much does a 1600 8v flywheel weigh ?
    Any ideas?
    How much shall I get it lightened by ?
    Cheers,
    Paul
  22. #20
    Jan 2002
    Cirencester
    MK4 Astra 1.6 SXI (Z16XE)
    why not get a f10 flywheel and clutch that would be lighter and still mate to a f13 or f10 box
    Stu.
    2 stroke tarmac terrorist
  23. #21
    May 2002
    liverpool
    Zafira VXR STAGE 2
    whats all this balancing the throttle malarky? what does it involve?
    oive just fitted an xe fly to my v6 cant wait to get it running
    Im a Daddy Wahoooo
  24. #22
    Dec 2001
    Chelmsford, Essex,
    You tap or hold the the throttle to get the engine and gearbox at the same speed, makes for very smooth gear changes.
