im changing the driver side driveshaft for a two piece drive shaft using half the drive shaft from turbo (long piece) and the other from the gsi(short piece) , on the end is a rubber seal like a rubber ring which side does this fit onto, into the end which goes into the gear box or the other end which mates up with the 2nd part of the drive shaft
