Oil Flush
Results 1 to 7 of 7
Thread: Oil Flush
    Jun 2002
    Nr Maidstone Kent
    Mk3 astra gsi
    Oil Flush
    Does anybody know the name of that stuff that you put in the engine so flush the old crap before you put the new in (and dont be smart by saying engine flush)
    Fabia Vrs
    Jan 2002
    Cirencester
    MK4 Astra 1.6 SXI (Z16XE)
    its called diesel
    or it is in my case
    read the tin its 90% diesel so charging 4 for about 20p of fuel is a rip off.
    Stu.
    2 stroke tarmac terrorist
    Jun 2002
    Nr Maidstone Kent
    Mk3 astra gsi
    Thread Starter
    mmmmmmmmmm
    Fabia Vrs
  5. Remove Advertisements
    Feb 2003
    Bristol
    Astra GTE 2.0l 8v
    Its called flushing oil. Put it in your old oil, let engine tick over for 10/15mins. Stop engine, changeoil and filter, repenish.Hope this is what you want. Its about 3..50 a tin.
  7. #5
    Feb 2003
    Glasgow
    various
    Its also known as 'rebuild your engine next month'.
    if the engines full of crap then it might not be a good idea to flush it.
    Seals start to leak, crud falls off and clogs up galleries and there goes yer big end.
    Chris
  8. #6
    Jun 2002
    Nr Maidstone Kent
    Mk3 astra gsi
    Thread Starter
    Right, i think i'll leave that one then.
    Fabia Vrs
  9. #7
    Dec 2000
    Gloucester
    3MW B18iS
    Good plan. Flushing oil is OK if you have an engine full of tar, but it can stir up things that were happily settled.
    No, now f*** ***.
